Dunlop - UV1-SC UniVibe Stereo Chorus [schematic]
- Tonetweaker
Hey all...
loubou mentioned wanting to get a peek at the Dunlop UniVibe Stereo Chorus, so here it is...
In Soviet Russia, dirt box fucks YOU!! ~ Seiche
- Tonetweaker
More...
I tried to take some close in shots, since the board is pretty tightly spaced. Please excuse the "jittery hand" quality though.
The board is pretty tightly held in by the pots, switch and jacks... The jacks had recessed threads, so that once you remove the retaining nut, there's no overlap with the chassis to worry about. As with most modern Dunlop products, they did a nice job of putting the unit together. I wouldn't be too nervous if this one got knocked onto the floor by mistake.
Of all my chorus/vibrato units, this one is my favorite. Good range and control.
As always, if more info or pics are needed, let me know. I'll keep it apart for a day or two to see if anyone has any requests or interest in reversing it.
Cheers...
Steve
Cheers...
Steve
- Tonetweaker
Sorry about the stray shot at the end. It got separated from the herd somehow, and there's no edit function available in this section.
- blackbunny
By golly, I think you're right....no lamps or LDR's. Completely different design to our "vintage" UV-1's.lolbou wrote:No bulb/LDRs in this one. Opamp phase stages. I guess it's all around the TL074, on the right of the switch...
How does it make that nice lush stereo chorus that Tonetweaker likes so much, using op amps?
- lolbou
That's what I supposed mentionning the TL074... Hey Tonetweaker, can you tell us what are the transistors around that 074 chip? Are these FETs?blackbunny wrote:using op amps?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- Tonetweaker
In fairness, you guys may not like this thing nearly as much as I do... My experience is fairly limited when it comes to effects. I don't have a lot of knowledge on what a lot of vintage circuits sound like, and when I hear a lot of my favorite recordings, I don't always know which "magic boxes" were responsible for that sound.blackbunny wrote:By golly, I think you're right....no lamps or LDR's. Completely different design to our "vintage" UV-1's.lolbou wrote:No bulb/LDRs in this one. Opamp phase stages. I guess it's all around the TL074, on the right of the switch...
That's part of the reason I'm here, BB... To learn from the guys that really know about this stuff.
That said, I really do like the sound of this thing. I use it all the time.
Yep. JFETs. All four are Fairchild 2N5952.lolbou wrote:That's what I supposed mentionning the TL074... Hey Tonetweaker, can you tell us what are the transistors around that 074 chip? Are these FETs?blackbunny wrote:using op amps?
Incidentally, anyone know what the little codes above the ID are for? Each one has a small code like "B419" or "D346"... Doesn't seem necessary for the ID. Perhaps a lot number or some kind of date code? All 4 are 2N5952, but each one has a different code above.
Cheers...
Steve
- lolbou
Expect something looking like the Phase 90 4-stage circuitry...Tonetweaker wrote:Yep. JFETs. All four are Fairchild 2N5952.
- Tonetweaker
That would certainly explain the swirly quality...lolbou wrote:Expect something looking like the Phase 90 4-stage circuitry...Tonetweaker wrote:Yep. JFETs. All four are Fairchild 2N5952.
I'm nowhere near familiar enough with these circuits to recognize close parallels to other effects. I'll have to dig up a schematic of the Phase 90 to give it a closer look. I'm sure I have it here somewhere.
- Dirk_Hendrik
As this "univibe" seems to be a standard 4 stage phase with FET's it would be interesting to see in which extend it is following the concept of a phase90 with altered coupling cap values. Which is more or less what people tend to call "univibing" when they rape a phase90 with altered caps and call it a "univibe".
- Tonetweaker
Could very well be, Dirk. I'm certainly no expert on either effect. It could be nothing more than a stereo Phase 90... but it sure sounds nice.Dirk_Hendrik wrote:As this "univibe" seems to be a standard 4 stage phase with FET's it would be interesting to see in which extend it is following the concept of a phase90 with altered coupling cap values. Which is more or less what people tend to call "univibing" when they rape a phase90 with altered caps and call it a "univibe".
This thing definitely provides a pretty nice range of sounds. More than my Phase 90 does, I'd say... not that there's anything wrong with that pedal either. I love the sound of a good swirly phase effect.
Somebody cue the psychedelic music...
Good question. I was curious as well... but as I mentioned, I'm not much on just looking at the board and understanding the circuit configuration. I wish I was, actually. It would keep me out of trouble sometimes...lolbou wrote:Any idea why there are two 4016 in it? Is it just for stereo purposes?
The outputs are labeled "Left/Chorus" and "Right/Vibrato" if that provides any clue...
The output jacks are right next to each other... The single one on the other side near the AC input is the input jack. The jack closer to the pot is the left channel. The one closer to the switch is the right.
- apollomusicservice
After several unsuccessful attempts to get the schematic for Uni Vibe stereo chorus,
I decided to draw my version.
This schematic is not official and I apologize if there is some mistake somewhere,
but it helped me to fix my Uni Vibe.
I hope it will be useful
Reason: Topic moved and renamed ;-)
This is a little corrected drawings with some measuring points to facilitate inspection of individual parts.
The test signal is 8oo Hz and the pedal is activated.
...and components placement
Hi, very useful thread this. I have one of these on the bench for repair. The owner said it was zapped with over voltage at a live gig from a dogy generator.
After finding the TLC2264AIN had blown as well as the tl074 I still have to find out why the bypass is not working.
This looks to be an older version and on this board R9 is a 1ohm resistor. Maybe they just replaced it with a trace.
This one has a resistor mod (300K) pin7 of the Hex-Channel Buffer to the RR54 / R49 junction.
Great sounding pedal though. I can't wait to hear it with 2 amps connected.
Has anybody checked to see what the control signal going to R4, R12, R19, and R40 looks like?
I'm guessing it is converted into a low frequency sweep voltage and not used as PWM to vary the JFETs apparent value, but I sure would like to know what the waveshape looks like (i.e., a low frequency sine wave, a warped low frequency sine, etc.).
Anyone every put a scope on it to see?
Thanks very much to apollomusic for posting all this. Really an interesting take on a very old effect.
mr coffee
mr coffee
Here is a demo of a vocal through the pedal and a live performance on the controls.
The first loop is with out the chorus and then again with.
https://www.dropbox.com/s/9z994kqwjui87 ... L.mp3?dl=0
(is it possible to upload .mp3's to this site?)
