OK I'm game
Controls are sweep, mids, growl and volume.
Referring to the
Geofex nomenclature :
Sweep is definitely
Rw (100k ?)
Mids is probably replacing the 1.5k
Rfb resistor
Growl : not sure but my money goes on
Re1. Wilson site says it increases gain and bass, and that's what Re1 does.
Volume : I'm still scratching my head on this one : The typical wah circuit delivers less than unity gain.
If there's a volume pot, there must be some additional gain somewhere. I see only 3 possibilities :
- maximum
Re1 value is lower than 470R. I doubt, this does increase bass response and clipping but not any meaningful gain at the wah output (verified with Spice).
Rin lower than standard 68k. And I'm pretty sure it is.
- Q3 is not setup as unity gain outbut buffer but rather as a fixed gain booster or something. I have my doubts here as well.
My guess is thus a low
Rin value and Q3 set up as buffer with a volume knob (voltage divider) right behind. Just like the McCoy wah buffer from
Fuzzcentral. But I might be wrong of course ...
It is interesting to note that this wah would then not have a "Q" pot, referring to the 33k
Rq resistor.
It seems Mr. Wilson decided to leave a fixed resistor here. Again, just a wild guess as the
mids control might refer to
Rq instead of
Rfb after all ...
Anyone has an idea of the purpose of both 47pF caps ? To smooth Q1 and Q2 response ?
Is that really a Ge diode I see there ?
I can identify a couple resistors but is there anyone with better eyes ?
I'm totally at a loss with the capacitors type/values. What is a "1, J" cap for instance ?
