blackbunny wrote:At the risk of being a smartarse, after following the progress of this topic it's apparent that there are lots of possible tones / waveforms when trying to produce 'tubelike' ('valvelike' for Aussies & Brits) overdrives and distortions.
Just take the difference between symmetrical and non-symmetrical clipping. There you have a major stompbox milestone, encapsulated neatly back in the mid 70's: the Maxon / TS symmetrical clipping versus the very similar Boss OD-1 with asymmetrical clipping.
Since most tube / valve output stages tend to clip fairly symmetrically if they're biased properly and the tubes / valves are reasonably well matched, and they tend to emphasize even-order harmonics which make a smooth sounding distortion, the magic distortion ingredient in the 60's was the transistor fuzz, which could produce spiky, asymmetrical waveforms loaded with (harsh sounding) odd-order harmonics. Plug a nasty fuzz into a smooth-sounding valve amp and PRESTO! Magic!
IMO, the 70's stompbox revolution was launched by the difference between symmetrical and non-symmetrical clipping, conveniently (and cheaply) created by diodes, and we're still exploring the possibilities over 30 years later.
It's actually the other way around, symmetrical clipping produces odd-order harmonics only, this is due to the resulting waveshape being somewhat square-shaped, Square Waves tend to sound hollow and slightly muffled to the human ear....
Contrast that with asymmetrical clipping, which contains both odd and even-order harmonics, the odd harmonics are caused by the sharpness of the clipping, and the even-order harmonics are caused by the asymmetry, the more asymmetric the waveform, the more prominent are the even-order harmonics, assymmetric clipping will therefore sound brighter and louder to the human ear....
A Sawtooth waveform also contains both odd and even-order harmonics too,as evidenced by the sharp corners and obvious waveform asymmetry,a sawtooth waveform tends to have a bright brassy sound to the human ear....
Check out this link:
http://milbert.com/articles/tubes_vs_transistors
