Rothwell Hellbender ?
andregarcia57
Has thanked: 50 times
Been thanked: 96 times
Post by andregarcia57 »
who have gut shots of the Rothwell Hellbender?
is a great pedal for AC/DC
andregarcia57
web shoot
matt239
Has thanked: 59 times
Been thanked: 5 times
Post by matt239 »
Rothwell Hellbender, Any news?
blackbunny
my favorite amplifier: Fender Blackface
Completed builds: Lots of mods to lots of pedals
Has thanked: 271 times
Been thanked: 105 times
Post by blackbunny »
Looks like the clipping circuit is 2 Zener diodes back to back in the op amp feedback loop; this type of clipping is supposed to give "tubelike" overdrive tones.
Jack Orman explains how it works in his diode clipping tutorial here: http://www.muzique.com/lab/zenmos.htm
The Hughes & Kettner Warp Factor is an example of a guitar overdrive pedal that uses lots of zeners for clipping.
This looks a lot like the first clipping stage of the Warp Factor.
matt239
Post by matt239 »
Cool thanks! :) It sounds really good to me in some of the demos.
blackbunny wrote:Looks like the clipping circuit is 2 Zener diodes back to back in the op amp feedback loop; this type of clipping is supposed to give "tubelike" overdrive tones.
don't those 3 pin SMD diode devices usually have 2 diodes per package? seeing as there are 2 of them, wouldn't that make it 4 zeners in the fb loop? I'm not all that familiar with everything SMD, but I know I have seen those dual diode packages before.
btw- it really bugs me when these demos show the "clean" signal, and it is totally distorted. I wouldn't trust that demo at all to show you what this pedal really sounds like.
blackbunny
RnFR wrote:don't those 3 pin SMD diode devices usually have 2 diodes per package? seeing as there are 2 of them, wouldn't that make it 4 zeners in the fb loop? I'm not all that familiar with everything SMD, but I know I have seen those dual diode packages before.
Now that you mention it, there could be either single or dual zeners in each package.
The single zener package is usually a SOT23, which has pin 3 (the one on it's own) as cathode and pin 1 (lower left if pin 3 is facing up) as anode.
The AZ23 package looks identical and has 2 zeners, pin 3 is common ANODES, pin 1 is cathode 1 and pin 2 is cathode 2.
These come in the full range of voltage values, so you need to decode the markings on the device.
If pin 2 is not connected or shorted to pin 1, you can assume it's a single zener.
matt239
Post by matt239 »
RnFR wrote: btw- it really bugs me when these demos show the "clean" signal, and it is totally distorted. I wouldn't trust that demo at all to show you what this pedal really sounds like.
AGREE!
Are you refering to the PGS demos? Those bug me. They're better produced than some demos online, but they play everything through small cranked tube amps;
"here's my clean tone: CKRRUNCH!!!"
- makes every OD sound just like their amp. - It's not a bad sound, but it's not the only sound, & doesn't tell you much..
(& then there are the countless thousands of videos with people using a crappy camera mic, 30' from the amp, usually with the gain & treble knobs maxed, not only doesn't tell us anything, but
- hurts my ears!!) :evil:
- but I've heard some better quality demos of the Hellbender, & it does sound promising.. :D
greigoroth
Been thanked: 12 times
Post by greigoroth »
AGREE!
I think Rothwell's own demos are about as good as any I've seen. Concise, good sound and covering a lot of territory.
matt239
Post by matt239 »
I like this one:
They never reference the clean signal, but it sounds pretty clean when they lower the gain on the pedal. - Sounds sweet!
TL072, zeners in feedback loop, & I guess, some careful tone shaping..
I'd guess they're using both halves of the TL072?
- I wonder if the diodes are in the loop of the first or second stage?
- I wonder if the TL072 clips even w/o the diodes? (as in a Sansamp..)
briggs
Has thanked: 27 times
Been thanked: 126 times
Post by briggs »
matt239 wrote:I like this one:
There's some LEDs in there too, maybe to ground after a second gain stage...
I am Klon.
mirosol
my favorite amplifier: Been on Bogner for quite some time now.
Completed builds: Over 1000 and counting.
Has thanked: 190 times
Been thanked: 446 times
Post by mirosol »
The board layout looks pretty much identical to Switchblade. I think there must be more differences than just one clipping pair though..
viewtopic.php?f=7&t=20613
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
