tc electronics xii programmable phaser guts
Fender3D
Has thanked: 120 times
Been thanked: 150 times
Post by Fender3D »
Thanks guys,
arph, yes very nice and versatile...
LFO modulation is hyper triangular, very musical.
I just changed the switching system, added LFO rate LED, and tweaked some values for deeper notches...
The 2 trimmers might as well be 2 controls, one is noise gate sensitivity, the other changes the "color" of the effect (shifts the notches higher or lower).
Gonna build another, I wanna see what I can do when 2 pedals are linked by the "program" jack...
Fender3D
Post by Fender3D »
Thanks guys,
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
Much nicer layout that the hideous mess of the original :wink:
armdnrdy1
Has thanked: 10 times
Been thanked: 67 times
Post by armdnrdy1 »
Hey Federico,
What did you use in place of the unobtainium XR4212 and RC4149 op amps?
And how is this phaser programmable?
Build looks great!
armdnrdy1
Post by armdnrdy1 »
Aahh...here's the user manual that explains the connections.
http://support.tcelectronic.com/entries ... r-s-manual
I guess I'll look at the schematic to see exactly what it's doing.
Fender3D
Post by Fender3D »
Hey Larry,
I'm fond of TL0xx, 074 in this build.
(R.G. said "when in dubt, use a 2N5088" referring to NPNs, I could mimic him saying "when i dubt, start with 741, then scale to a better device until it works..." referring to op-amps) :D
I guess they're even less noisier than stock ICs...
"Programmable" is a bit tricky, since I can't imagine a guitar player down on knees swapping plugs, on stage...
Anyway there's a stereo jack, whose ring affects depth and tip affects "range" or the "starting point", (notice that one trimmer simply sets this starting point).
By appling a stereo jack with 2 resistors, one GND-tip and one GND-ring, you can "program" different phaser settings.
Since these are connections after the LFO, and working as variable resistors to GND, you can connect a volume pedal acting as a flanger's manual control, another XII's program...
I started populate another board already ,just waiting for photocouplers...
PS
look at how simply they made a noise gate out of a comparator... :secret:
armdnrdy1
Post by armdnrdy1 »
Thanks for the explanation Federico,
I took a look at the drawing but..was thrown off a bit by the labeling numbers...1R, 2R, 2L, 3L etc.
This drawing is kind of hard to follow in places. Yes..the 339...I didn't notice that. That's a departure from the norm!
Fender3D
Post by Fender3D »
I know...
It's easier if you imagine looking at the (Cliff) jack sockets from connection side, 1R GND lug, 1L GND switched lug and so on...
U3a is a nice way for inverting signals (ie, instead of ADA flanger's phase switch)....
armdnrdy1
Post by armdnrdy1 »
Got it...the jack drawing is viewed from the pin side. The "L" and "R" is Left and Right.
That is confusing! I think that a standard symbol for the jacks would have been much more self explanatory!
So a pot is controlling the signal inversion instead of a switch?
Fender3D
Post by Fender3D »
Yep,
it's the "real world" version of the variable gain op-amp you can find on books...
it has inverting gain (-1) on one side, no gain in center and non inverting gain (1) on the other side.
BTW it's a perfect fit for Tayda's W20K Tone Control Potentiometer with Center Detent :horsey:
P_V_P
Post by P_V_P »
I understand that eight and a half years in the life of a DIYER is not just a lot, but a lot. And the pedal is so interesting that interest in it is still great, and sooner or later, those who are looking for information on it will stumble upon this publication. I'm one of them.
Fender3D, please share your impressions of "your vision" of TCXII. Did you like the result /are you satisfied? What replaced the XR4212 and programmable RC4149? Is it possible to see the pcb in any format?Patience and delicious sound for all of us.
