6N16B True tube overdrive with SMPS supply
DarkRain
Has thanked: 13 times
Been thanked: 181 times
Post by DarkRain »
Hey guys just made my dream come true :) a tube overdrive with 300v anode voltage from a 12v supply. The base schematic is from Matchless Hot Box (i used a BigMuff tone controll from RG site), it's also has a volume and gain controll. The SMPS it's based on a NIXIE design but i modify it so the 555 will oscillate at a higher freq. (about 40-45kHz). Some pictures and a sound clip that was recorded useing a ROG Condor cabsim. I'm waiting for your opinion (also if someone is intrested i will post all the schematics that i used and also the PCB design - they are made from 0 by me).
Best regards,
Gabriel Tudoran
Analog Sound
http://dl.dropbox.com/u/15275178/Pictur ... rDrive.mp3
danielzink
Completed builds: Too many: www.danielzink.com
Been thanked: 27 times
Post by danielzink »
DarkRain wrote:Hey guys just made my dream come true :) a tube overdrive with 300v anode voltage from a 12v supply. The base schematic is from Matchless Hot Box (i used a BigMuff tone controll from RG site), it's also has a volume and gain controll. The SMPS it's based on a NIXIE design but i modify it so the 555 will oscillate at a higher freq. (about 40-45kHz). Some pictures and a sound clip that was recorded useing a ROG Condor cabsim. I'm waiting for your opinion (also if someone is intrested i will post all the schematics that i used and also the PCB design - they are made from 0 by me).
Best regards,
Gabriel Tudoran
Analog Sound
I like it !
The gain isn't so "over the top" maybe the BMP tone control is taming it down a bit - but I do like it a lot.
Where was gain set on your clips ?
Dan
http://www.danielzink.com
MoonWatcher wrote: Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
DarkRain
Post by DarkRain »
Best regards,
Gabriel Tudoran
Analog Sound
I like it !
Dan
That was 80% from maximum gain - it's not a high gain pedal it's more like a medium gain overdrive. Glad you like it and hank you for your reply.
Best regards,
Gabriel Tudoran
Analog Sound
himister
Has thanked: 21 times
Been thanked: 28 times
Post by himister »
Good work Gabe!!! Sounds very good. :wink: :applause:
First thought...it would be awesome to make everything on one pcb and put it in a 1590BB enclosure. If you'd like I'd be glad to help with it! :D
Can't wait to see the schematic.
Cheers and keep the good work! :thumbsup
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
Shit man that PCB is terrorized........ :?
but I like the sound :thumbsup
Boris
himister
Post by himister »
borislavgajic wrote:Shit man that PCB is terrorized........ :?
Boris
Guess it's made from a bitmap file, not vector graphic...but, looks like a prototype...it could be better with little workout! :wink:
Good idea non the less!
DarkRain
Post by DarkRain »
Boris
:lol: :lol: :lol: Was done using some not so good glassy paper - was done in Eagle but it looks better in reality then the picture... and also the traces ware little bit to thin... but i'm happy with it :P nobody will bother to open it :D
I'm very happy that you like the sound.
Best regards,
Gabriel Tudoran
Analog Sound
borislavgajic
Boris
Best regards,
Gabriel Tudoran
Analog Sound
Hey man.....do not get me wrong..........I like everyting about this project..... :thumbsup .....can you post schem please......Bajaman was talking about this tubes need to be biased differently than 12AX7 and ecc83.........
I would like to make tubezipper and blackfinger with those submini tubes
Boris
Emanuele
Post by Emanuele »
+1 post the schems please! I'm really really interested about those SMPS power supply!
DarkRain
Post by DarkRain »
There there :)
http://dl.dropbox.com/u/15275178/MDrive ... _ne555.JPG
http://dl.dropbox.com/u/15275178/MDrive ... -NE555.pdf
http://dl.dropbox.com/u/15275178/MDrive ... rDrive.JPG
Best regards,
Gabriel Tudoran
Analog Sound
PS: on my smps i used C1=1.8n (it's better to use a higher freq.), so all the rest is the same as here ;) I'm waiting for some build reports. Thank you a lot guys for your interest.
Emanuele
Post by Emanuele »
can you give me some details about the inductance? there are some more critical values to look at other than 100uH?
DarkRain
Post by DarkRain »
Emanuele wrote:can you give me some details about the inductance? there are some more critical values to look at other than 100uH?
No critical values +/- 10% will do just fine. The inductance is on ferite core and shoud have over 500mA maximum current (600-800mA will be just fine). Nothing other then that (you could also experiment with 180-200uH).
Best regards,
Gabriel Tudoran
Analog Sound
danielzink
Gabriel,
WIll you be posting the layout for the mainboard as well ?
As himister said - it would be great to integrate everything onto one board - or maybe there's a reason you kept them seperate ?
Dan
DarkRain
Post by DarkRain »
danielzink wrote:Gabriel,
Dan
Hey Daniel,
There it is the layout for MD, i wouldn't go to integrate the SMPS on the main board...could be trouble regarding noise... but it would be nice to do that. :horsey:
Best regards,
Gabriel Tudoran
Analog Sound
DarkRain
Post by DarkRain »
The SMD version of the SMPS
Best regards,
Gabriel Tudoran
Analog Sound
borislavgajic
:applause: It could be even smaller than 9V battery :thumbsup
great project......... :thumbsup :thumbsup :thumbsup
Boris
DarkRain
Post by DarkRain »
borislavgajic wrote::applause: It could be even smaller than 9V battery :thumbsup
Boris
Thank you Boris,
Yes it could be much smaller then a 9v battery (next prototype will use 0805 SMD). I will make a more compact PCB (hope i can solder them after :D as my eyes are a little bit tierd). Thank you for your appreciation guys.
Best regards,
Gabriel Tudoran
Analog Sound
DarkRain
Post by DarkRain »
Just got a bunch of 6N21B submini tubes (max. amplification in 100) i can't hardly wait to see how they sound - i will keep you posted guys :D
Best regards,
Gabriel Tudoran
Analog Sound
DarkRain
Post by DarkRain »
The Frankenstein (used a test enclosure), no hum no noise no nothing for now, anode voltage is @ 220v. The clip was recorded using this pedal, a condor cabsim and REAPER (with a little reverb on solo part), no other eq or effects used.
http://dl.dropbox.com/u/15275178/MDrive/MasterD.jpg
http://dl.dropbox.com/u/15275178/MDrive ... Drive2.mp3
Best regards,
Gabriel Tudoran
Analog Sound
DarkRain
Post by DarkRain »
A new model (much more gain) with 6N21B double triodes and some audio clips, the recording chain was: Guitar / Tube pedal / Condor cabsim / Sund card.
Clips:
http://dl.dropbox.com/u/15275178/Crunch ... Ibanez.mp3
http://dl.dropbox.com/u/15275178/Crunch ... -Strat.mp3
Best regards,
Gabriel Tudoran
Analog Sound
