Hi Emanuele,Emanuele II wrote:I resume this post for some questions..
Today I finished my valve pedal..it works flawlessy except for boring HUM, it sounds similar to a 60hz cycle hum, but that's strange since my power adapter is hum free..as soon as I connect other dirt pedals with a daisy chain they became useless as the hum rises up with the gain..![]()
On a side note my build is a bit different:
I put togheter the first two gain stages of a plexi, built around a 12AU7, my SMPS is built from scratch, and while I'm waiting for the right mosfet, it now pumps out 70V from a 9V boss style PSU..
Be aware that not any old mosfet may work with this,,,better minds here can explain details.
70VDC seems rather low?
I would think you should get 150/190 VDC from a 9 volt supply?
As too good old hum;;
Make darn sure you watch the ground path for the heater as this can cause all sorts of issues if you get it wrong in the layout.
Keep Audio and heater ground on separate wires/traces until they meet at supply node is the best way I can explain that.
Phil.
