Have a MXR block logo phase 90 with the EVH script button hiding underneath. Will drill a hole, I'd like find the same button (http://www.jimdunlop.com/product/evh90-phase-90).
Any help appreciated.
Looking for EVH phase 90 Script button
- Ice-9
I have a EVH phase 90 and i broke the button, I couldn't find one anywhere to fit, they are a small dpdt latching mini push button switch. Only one pole of the switch is used so if your happy you could just use a spdt mini toglle switch in there.
