Threebanger fuzz/OD/Distortion schematic
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
I've put together a schematic for an OD/distortion/fuzz "inspired by" (stolen from) soulsonic's fourbanger. It's three boosters threaded together, comprising of a simple silicon transistor boost posted by mictester -> soulsonic's CNO -> AMZ miniboost. I'm waiting on parts before I can try it out, so if anyone could look over it and offer advice/suggestions/improvements/potential problems/howling errors, I'd be very grateful.
- jonasx26
Hey!
A couple of suggestions;
Place the 100R resistor before the 100µ capacitor. As drawn, it will not be very effective as a V+ rail lowpassfilter..
The 1N5819 is most probably a polarity protection diode, it will only protect the CNO and Minibooster. I suggest you put it first, i.e;
DC-jack > 1N5819 > 100R > 100µ > [+9v to circuit]
edit:
(Actually, you will get a voltage drop across the 1N5819 and 100R.
So you won't get 9v to the rest of the circuit..)
Also, you won't need both the 2.2µ AND the 220n capacitors between mictester's boost and the CNO. I'd remove the 220n and the 100k resistor to ground.
Same goes with the caps between the CNO and the minibooster-stage.
One cap is enough to remove any DC, so remove the 10µ and 100k at the CNO output.
Otherwise you should be good to go. Ask away if something is unclear, I'm swedish and it's kind of difficult to explain this stuff.
/ J
edit:
/ J
@jonasjberg http://futileresistancefx.blogspot.com
- Greenmachine
- my favorite amplifier: Fender Blackface Deluxe Reverb
- Completed builds: Electra Distortion
Roger Mayer Octavia
Klon Centaur (Bajaman/Soulsonic)
DOD 440 Envelope Filter
MXR Phase 90
DOD FET Preamp
Dallas Arbiter Fuzz Face
Soulsonic Hunny Bunny Overdrive
BYOC Analog Delay
Craig Anderton Headphone Amp
Anderton Mini Amp
Bajaman Real Tube Overdrive
Fender Deluxe 5E3 with Tone Stack Mod.
Fender Princeton 5F2-a
Keen Neovibe
Aquapuss Delay
Anderton AMS-100 Guitar Synth (abandoned)
DOD 280 Compressor
Weird Sound Generator
Beavis Audio Noisy Cricket
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
Really Cheap Compressor - Location: Jersey City, NJ
- Has thanked: 87 times
- Been thanked: 15 times
- Contact:
When you're done building your CNO, will you let me know if it's blazing-ass loud? I like mine, but I have the pot all the way off and I still get all the boost I need.
Thanks.
Thanks.
- Nocentelli
Many thanks for the help: I was also a bit unsure about the two capacitors between each stage - I posted a question in the workbench section but no-one repliedjonasx26 wrote:Hey!
A couple of suggestions...
One further question - I might put in a simple treble cut/boost pot: Where is the best place for this? I was thinking after the CNO but before the AMZ?
I'll make some changes an re-post soon.
- jonasx26
I would try a passive low pass filter first, google "stupidly wonderful tone control" for some ideas..One further question - I might put in a simple treble cut/boost pot: Where is the best place for this? I was thinking after the CNO but before the AMZ?
My guess is, as each stage is boosting, you'll get a somewhat hot signal feeding into the minibooster-stage even when the two 'gain'-controls are turned down. A passive filter would attenuate your signal some, but that wouldn't be a problem.
Try it out, maybe it'll be sufficient. If it doesn't provide enough treble boost you'll need an active filter stage..
I think the hardest part of designing a overdrive/boost/dist., is deciding where and how to filter the signal. IMO it's also the filtering pre/in/post -stages that define the character of the effect.
SO, it depends on what sound you're after. I'd suggest breadboarding the circuit, experiment and see where the tone control works best.
All the best! / J
- Nocentelli
Thanks again, this is what I'm going to try out as soon as my parts arrive:
- jonasx26
Cool! Would be interesting to hear what it sounds like.
