Boss - PH-1r ( Phaser )  [schematic]
candletears7
Been thanked: 5 times
Post by candletears7 »
If there was a layout and/or a pcb, it would most likely be in this thread.
Anyway, a have one on my bench for a mod.
It needs to be truebypass and a volume trim pot put in to bring the effect signal down in comparison to the bypass, as there is a noticeable volume jump.
I'm using Millenium bypass and a dpdt switch to fit in the flip flip hole, but I need to hardwire the circuit always on.
Reading this:
http://www.geofex.com/Article_Folders/bosstech.pdf
I need to remove sW3 and jumper the source and drains of sW1 and sW2.
Given the schematic and pcb shots given earlier in this thread, could someone help me identify those 3 FETS?
Has thanked: 232 times
Been thanked: 886 times
There is no sw3 in this case.
Jumper the source drain connections of Q5 and Q6.
candletears7
Brilliant. Thanks mate!
candletears7
all wired up with the trim and works great. I'll apply thinto another one I have to do, the hf2 hi band flanger. thanks again Dirk!
birgitay
Post by birgitay »
regen pot What is the value?
Has thanked: 4392 times
Been thanked: 2130 times
BOSS-PH-1R-SERVICE-NOTES.pdf
Boss PH-1R service notes 1988
(2.71 MiB) Downloaded 228 times
