I'm working from a library called ota.lbr (available for download at the EAGLE CAD website). What I have noticed is that it seems to be impossible to have enough connectors in a DIL8 package to include the +V on the sink output/collector. In the circulating schematics and datasheets this is listed as pin8. Noticing this, I double checked the NE5517s in my project schematic and noticed that I could not connect a signal from that point to +9V.
Is there a workaround for this or has anyone else come up against this problem?
Here's a screengrab to illustrate the problem in the schematic, I've pulled the output darlington across to show that it is not connected. No matter how i try the signal will not connect to the sink output/collector because there is no pin connected to the symbol within the package design.
