Female Terminal Connector for DC Jack Lugs?
- snmavronis
- my favorite amplifier: Marshall
- Completed builds: My DIY stompbox builds:
- Neo-Classic 741 Overdrive (gray spec 250 Overdrive clone)
- MXR Distortion+ (diy replica pcb replacement 1980 block logo)
- Neo-Classic 3080 Compressor (script spec Dyna Comp clone) - Location: Maryland, USA
- Has thanked: 1 time
- Been thanked: 14 times
- Contact:
Are there any mini female spade terminal conenctors that would fit onto the lugs of the plastic Boss style 2.1mm DC Jack? Since they are tightened down from the inside with a nut they are hard to remove and to solder wires to them anyway. I thought if my wires had quick disconnect terminal conenctors it would be easier to deal with. Just have to figure out the smallest size that would fit.
Guitar > Boss NS2 Noise Suppressor > NS2 Send > MXR Custom Comp > Neo-Classic 741 Overdrive > NS2 Return/Output > VHT Special 6 Ultra Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
- snmavronis
- Contact:
Someone just told me about inside mount plastic DC jacks so maybe this isn't needed.
- snmavronis
- Contact:
I don't like the threads showing either. It would be alright if the outside nut hid them. I'll experiment before my next build.
- CRBMoA
You can also use washers on the inside to reduce thread exposure.
It's not one of the nits I choose to pick myself, but I have heard the complaint before.
I actually liked the external nut jacks when I had fewer builds under my belt, but I can see why the internal nut design is more popular, and I will probably go back to using those in the future. Not that anyone cares, I just have had too much coffee this afternoon.
cb
cb
atreidesheir wrote: Let's build some damned pedals!
