SolidGold FX - Electroman delay
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
Can't get this one working again, so I'm going to do a full trace to help isolate the problem. :D
culturejam
Removed the dual op amp and the pots so I can see the traces better.
As you can see, there are pads for a SPDT board-mounted switch under where the Tone pot sits. There are also two empty spaces on the board for caps that connect to the switch. So obviously they planned this to either have a tone pot or a tone switch. Interesting.
I'm getting GOOD at desoldering from plated through-holes. :thumbsup
Sorry about all the fiber/lint on the PCB. I used acetone to remove the last vestiges of goop, and then I rubbed it off with a towel. Didn't notice the lint until I zoomed in tight. :D
culturejam
I had to take a break from this one. I got all turned around after flipping the board over 300 times and looking top-down with a flashlight shining through the bottom. 8)
~arph
Has thanked: 60 times
Been thanked: 163 times
Post by ~arph »
culturejam wrote:I had to take a break from this one. I got all turned around after flipping the board over 300 times and looking top-down with a flashlight shining through the bottom. 8)
Lol, you could make a photo of a strong light shing through and put that up on your computer screen.. No more flipping over.
~arph
Post by ~arph »
Ignore my spelling.
Apparently you can't modify your posts if you quote someone..
culturejam
The black solder mask makes this quite difficult. I'd need to hook up my high-power "work" light to make that happen. I'll get back to tracing this one soon, I just got caught up in a few other things in the meantime.
~arph
Post by ~arph »
Ok cool, I'm very interested in all filter sections of all pt2399 based delays. As I'm working on reducing clock noise with four pt2399's in series.
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
Have you tried a second order filterLike in the belton brick? More like a cliff than a slope with some component choices
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
Great job going on there Culturejam, looking forward to seeing this one progress. :applause:
audioguy
Has thanked: 22 times
Been thanked: 7 times
Post by audioguy »
culturejam wrote:I'll get back to tracing this one soon, I just got caught up in a few other things in the meantime.
Cool... its interesting to hear the various uses of the 2399.
Thanks for your effort!
~arph
Post by ~arph »
Hides-His-Eyes wrote:Have you tried a second order filterLike in the belton brick? More like a cliff than a slope with some component choices
I was mainly tinkering with MFB filters, but I had a :slap: last night. Most of the noise comes from the summing amp. I have to switch to a non inverting configuration and use a JFET input opamp instead of the NE5532 I have there now.
pietro_moog
Been thanked: 48 times
Post by pietro_moog »
i'm sorry to break balls, but, is there any progress?
coldcraft
Has thanked: 38 times
Been thanked: 84 times
Post by coldcraft »
that looks almost more like it was meant for a pot with a push/pull knob switch.
culturejam
pietro_moog wrote:i'm sorry to break balls, but, is there any progress?
Nope. :lol:
pietro_moog
Nope. :lol:
Nice. take your time.
i'm really interested in that tone control.
culturejam
askwho69 wrote:im interested on the warp part :D
It's a momentary footswitch that toggles between either the resistance of the Repeats pot or a fixed value set for oscillation.
teej212
Been thanked: 8 times
Post by teej212 »
i was under the impression that it just took the first and third lug of the feedback pot and shorted them. i tried that in a rebote project and it yielded the same effect.
culturejam
teej212 wrote:i was under the impression that it just took the first and third lug of the feedback pot and shorted them. i tried that in a rebote project and it yielded the same effect.
It very well could be that, as I haven't specifically traced that part of it yet. But I know the momentary switch is overriding whatever resistance is set by the Repeats pot with something lower (perhaps no resistance).
At any rate, it's an easy thing to add to just about any delay.
audioguy
Post by audioguy »
Any progress on this guy?
pietro_moog
hi.
do you think you will extract a schematics from this sooner or later?
