dbat69
do you have a breadboard yet? if not, get TWO or three.. them pocket sized ones are wicked handy.
you can play with the cap values some and get it to go a bit faster, but as it goes slower it'll lose depth and like he said become unstable and stop.
that said, if ya find a couple cap values in the timing part of the circuit that work for you, just put your caps on a dpdt switch... i like them on/on/on dealios for this... solder your normal value across the middle, and two bigger caps, or a bigger and a smaller one, on the outside lugs.
take your input and output from the same terminals as the cap across the middle poles. this way you have stock cap, and either larger or smaller depending on the size of the caps. remember, caps in parallel act like resistors in series. so you can kinda ballpark the sizes to the closest standard values you have on hand and get some good results.
this trick also works great anywhere you need to change cap values.
you can also do it with a spdt, or a 3pdt.... in the 3pdt case, you can even use a tri color led if ya want
works great for inputs on fuzzes. i often put stuff like this on what i call "phat" switches, make it like a stompbox. in this case, you may need to add some big freakin resistors (i like 4.7m cuz i have like zillions of them) to ground from some of the nodes of the switch. sometimes i set it so it changes the input and output caps at the same time... you can really get on top of tones that way.
if ya use a spdt, same deal, but just tie the free ends of the 3 caps together. that will be fine, too.
experiment with the led's too if not using a vactrol... different sizes, colors and orientation to the ldr can make a big difference. i liked a 10mm jumbo ultra clear white one in mine, but i imagine orange yellow or green would probably work better.
i haven't tried it yet, but i'm gonna have a play with some of them little 3.5mm xmas bulbs... they have wire leads and are incandescent, and i've been curious for a while if it would change the way the effect sounds. if ya gotta breadboard... you will become triumphant. most of the time.
sorry for the slight OT hijack.... peace
