Bigfoot FX Magnavibe [traced]
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
Haha - To clarify - The second (verified) layout is correct in terms of pin-out.
When you swap the transistors, the LED should start flashing immediately. If it doesn't, I'd then swap the LED around. Also, you'll probably get more depth if you have the LDR facing the LED straight on.
- Nocentelli
...also I've just tried it out through a bigger amp at higher volume, and there is some quiet, but noticeable ticcking/brrrr-ing: I'd definitely try out some power filtering...
- kinski
Hmmm....okay....turned the transistors around and it all works now. The only thing is, there is not much "vibrato" going on. Its sounds much more like an okay sounding tremolo...even with the depth all the way up. What could the cause of this be? I'm using a bright white LED.
- Nocentelli
That's totally normal: The flasher circuit runs all the time.kinski wrote:Okay, noticed another strange thing....the LED flashes even when clicked off to bypass. WTF?
As far as a lack of depth, the LDR type and LED brightness will affect the maximum depth of the effect. You need to have the LED facing the LDR directly, preferably taped together or surrounded in shrink-wrap. My LDR is labelled 24k-72kOhm (1M), and at maximum depth the effect is a fairly seasick vibrato.
- kinski
From the pictures from the degoop, it looks like that is what is used.
Also, with the depth all the way up, it gets pretty choppy, but its more of a tremolo...not much ,if any, pitch bending.
- kinski
Okay, so it does work just fine. Its just much more subtle than I thought. I moved the led and photocell around a bit and got sounding pretty good. Anyone find a good color led to use? Whats the original use? The white one im using does not sound so good when the depth is up all the way.
- KindaFuzzy
- Degoop Doctor
Original had a superbright red waterclear 10mm. I think I used a superbright yellow 3mm in the one on my breadboard since the LDR I had was pretty small.kinski wrote: Anyone find a good color led to use? Whats the original use?
- culturejam
Has anyone drawn up a unified, electronic format schematic for this one?
- RnFR
not yet. I volunteered earlier, but have been busy on other projects. sorry about that! feel free to take the reigns, if you're willing.
- MullisMan
- my favorite amplifier: Dr. Z Maz 18 Jr.
- Completed builds: Timmy, Klon, Zendrive, King of Tone, Rat, BSIAB2, Riot!, Fuzz Factory, Coloursound Overdriver, Divided by 13 Joyride, 70 Fuzz, BBE Sonic Stomp, Big Muff PI, Xotic EP Booster, Lovepedal Eternity, Jack Orman Minibooster, Dynacomp/Ross/Keeley Compressor, SHO
- Has thanked: 4 times
- Been thanked: 55 times
Will this do?
*mod edit: old version deleted
I want to build it all.
- bigorangefan79
Looks good to me... but the LDR is a light dependant resistor, not a capacitor.MullisMan wrote:Will this do?
- MullisMan
I know
....I didn't have a parts library for an LDR so I just went with what was handy.
- MullisMan
Here's a layout and transfer as well if anybody's interested. Should be able to fit it into a 1590A. This layout isn't verified however.
*mod edit: old layouts removed
- culturejam
The libraries that are available in the link below have LDR included (as well as all sorts of other awesome stuff):MullisMan wrote:I know....I didn't have a parts library for an LDR so I just went with what was handy.
http://gaussmarkov.net/wordpress/tools/ ... libraries/
- MullisMan
Hmm....I actually use gaussmarkov's library and I couldn't find any LDR parts in there. I don't see any description for it on that page either. I've looked in the categories but couldn't locate one. It's probably hiding right in front of my eyesculturejam wrote:The libraries that are available in the link below have LDR included (as well as all sorts of other awesome stuff):MullisMan wrote:I know....I didn't have a parts library for an LDR so I just went with what was handy.
