Bigfoot FX Magnavibe [traced]
- MullisMan
- my favorite amplifier: Dr. Z Maz 18 Jr.
- Completed builds: Timmy, Klon, Zendrive, King of Tone, Rat, BSIAB2, Riot!, Fuzz Factory, Coloursound Overdriver, Divided by 13 Joyride, 70 Fuzz, BBE Sonic Stomp, Big Muff PI, Xotic EP Booster, Lovepedal Eternity, Jack Orman Minibooster, Dynacomp/Ross/Keeley Compressor, SHO
- Has thanked: 4 times
- Been thanked: 55 times
Thanks madbean, I see it now
I actually went back and added a part from the stock eagle libraries that I like better than gaussmarkov's. I have an updated schem and layout, perhaps a mod would like to delete the original, and I can post the new one along with the layout and transfer. I don't know what's wrong with my flickr links above.
I want to build it all.
- culturejam
Removed the old schematic/layouts.
As for why the Flickr link wasn't working, there was too much Flickr-centric code in the links. They should be whittled down to just this:
Code: Select all
[img]http://farm6.static.flickr.com/5183/5639232035_de56230ac7.jpg[/img]
[img]http://farm6.static.flickr.com/5223/5639805702_90b93af29e.jpg[/img]- MullisMan
Thanks culturejam. I've attached my eagle files along with a BOM, layout, and PCB transfer.
MagnavibeEAGLE.zip- Eagle Files for Magnavibe
- (325.94 KiB) Downloaded 407 times
- pietro_moog
nice.
guys, could you suggest me an appropriate LDR for this project?
is there any filtering at all on the 9v dc?
- KindaFuzzy
- Degoop Doctor
No filtering on the stock unit, couldn't hurt to add if you're going to use a power supply. I couldn't recommend anywhere to order an LDR, since I get mine locally, but one with a big swing sounds best to me and is closest to the original. One that goes from about 1k-20Meg should be good.
- pietro_moog
thanks.
wow, 1k to 20M is a very large range. i'll get a cheap one and see what's happening
So, a 20M at dark is perfect?KindaFuzzy wrote:No filtering on the stock unit, couldn't hurt to add if you're going to use a power supply. I couldn't recommend anywhere to order an LDR, since I get mine locally, but one with a big swing sounds best to me and is closest to the original. One that goes from about 1k-20Meg should be good.
- KindaFuzzy
- Degoop Doctor
Should be, as long as it gets nice and low with the led shining on it. I think I tried one that went from 500R to 2M and it was good too.
- DimebuGG
I got nothing to do so I made a layout on this little circuit..enjoy!
Notice, I didn't include the 4.7K current limiting resistor of the status LED. That won't be a problem, right?. Instead, I added pads for power supply filtering(marked in parenthesis).
MAGNAVIBE PCB.pdf- (47.01 KiB) Downloaded 291 times
- magnavibe.PNG (17.99 KiB) Viewed 2514 times
- pietro_moog
nice.
i have a VTL5c2 unused, do you guys think it might work correctly?
- greenskull
Might be a good idea to throw this on the breadboard first in case you need to experiment with component values to make it work with your opto. At least install sockets for it on the pcb to swap it out easily if it doesn't work well with stock values.pietro_moog wrote:nice.
- pietro_moog
hi guys.
do you think there'll be a difference between a 5mm led and a 10mm one?
i have a 5mm red ultra-bright so i think i'll give it a shot.
objections?
objections?
- KindaFuzzy
- Degoop Doctor
You can use it just fine, if you can live with the lower level of mojo.
- culturejam
I just noticed that Big Tone Music Brewery (the boutique brand operated by the owner of BYOC) has a Magnatone vibrato pedal:
http://bigtonemusic.com/maggie.html
Sound convincing. Kieth generally knows his shit, so I feel like this would be a pretty damn good clone of the original sound.The BTMB Maggie sounds exactly like the real Magnatone 280 because it basically is. We've simply translated the original circuit into a low voltage solid state form. Right down to replacing the 8 varistors that were in the original circuit with JFETs. The most important part of replicating the tone of real Magnatone vibrato is the dual phase LFO (low frequency oscillator). Without it, you cannot have the push-pull effect that gives the Magnatone its lush rich warble....not even when it's in normal(mono) mode. And you certainly can't get the stereo effect that the 280 had where the sound coming out of one speaker was bending the pitch up, while the sound coming out of the other speaker was bending the pitch down.
- pinkjimiphoton
- my favorite amplifier: my own, a redesigned princeton
- Completed builds: so fucking many goddamn pedals it would make your ass hurt just looking at 'em all!!!!!
there's videos that totally suck of about 90 of 'em here:
http://youtube.com/666pinkster
gimme a like: http://facebook.com/pinkjimiphotonrocks - Location: new world order land (formerly la-la land)
- Has thanked: 358 times
- Been thanked: 476 times
- Contact:
hi guys, thanks for what looks to be an awesome project...i'm kinda a newbe still tho, and don't understand where the different parts of the schematic connect?
can anybody enlighten my idiot self?
thanks!!
thanks!!
Slava Ukraini!
Slava Ukraini!
- pinkjimiphoton
- Contact:
ooops...brain death, sorry...too much blood in my caffiene system i guess...
i found the schem/layout, don't know how i missed the first two pages!!
thanks guys, i'm a-gonna get me the parts tomorrow and give it a whirl!!
Slava Ukraini!
Slava Ukraini!
- RnFR
no that sounds interesting. what do you think KF? you gonna flip for this one, too?culturejam wrote:I just noticed that Big Tone Music Brewery (the boutique brand operated by the owner of BYOC) has a Magnatone vibrato pedal:
- KindaFuzzy
- Degoop Doctor
We'll see, once I sell the sweet, this may be the next on the chopping block.
- The Rotagilla
Keith's been working on this for awhile. I have a schematic dated 2007 of the Maggie but no idea how much has been changed since then.RnFR wrote:no that sounds interesting. what do you think KF? you gonna flip for this one, too?culturejam wrote:I just noticed that Big Tone Music Brewery (the boutique brand operated by the owner of BYOC) has a Magnatone vibrato pedal:
