BAJA Sagittarian Charger (mini KLON)  [documentation]
aegert
Has thanked: 39 times
Been thanked: 56 times
Post by aegert »
Looks perfecet.. Nice Job would love one of those boards!!! would you ever make a few and sell um or trade?
mountainsforclouds
Post by mountainsforclouds »
Hey guys I know its been a while since someone has posted on this. I built one of these and it works amazing sounds so good. I recently built another one the same way and the gain stage is really acting funky. As I turn the gain up the volume decreases and around half way and up if you play through it there is a really "farty" sound coming out of it. I checked all the solder joins and they look good. But I can't seem to figure it out. I don't even have to have the pedal on to have it affect the sound. It still gets farty. Any help on troubleshooting would be great! Thanks!
stonefreed
Has thanked: 27 times
Post by stonefreed »
If it sounds too farty you could have made a mistake with one of the capacitors , probably way too big .
Check it again.
pinkjimiphoton
my favorite amplifier: my own, a redesigned princeton
Completed builds: so fucking many goddamn pedals it would make your ass hurt just looking at 'em all!!!!!
there's videos that totally suck of about 90 of 'em here:
http://youtube.com/666pinkster
gimme a like: http://facebook.com/pinkjimiphotonrocks
Has thanked: 358 times
Been thanked: 476 times
Post by pinkjimiphoton »
ALSO check the wiring to the dual pot...from your description, a couple wires may be crossed. some of the layouts floating around aren't really clear, so check it against the schematic, cuz that i know IS right 100%
Slava Ukraini!
mountainsforclouds
Yeah all of the caps are good. I went over those like crazy. I know I redid the gain pot, but I did just redo it to the layout thinking I just did it wrong the first time. The first thing I noticed was a backwards diode. I stupidly put one of the 1N34A's backwards, I fixed that and thought things would be fine and dandy, but same problem as before. I also changed out all the IC's thinking maybe having the diode switched that I fried something in the chip, but nothing there. But I will check the gain pot from the Schematics. Also I unplugged my guitar from the pedal as my amp was powering down and it gave a high pitched whining sound... I don't know if that is coming from the same problem but maybe that will help.
mountainsforclouds
I figured it out there was jump between two traces! Whew glad it works now. This is really probably the best overdrive I have played! Thank you for your help guys!
pinkjimiphoton
awesome. it's easy to do, especially right where the b+ goes in. REAL close.
i wear two pairs of 2.0 reading glasses (hah, in series!!) to examine boards now...comes in handy!!
glad you're in business...it really is a nice sounding dirt box.
Slava Ukraini!
mountainsforclouds
Haha! Yeah I should look into that for sure. Thanks again for you help. I absolutely love this pedal.
Moonibopper
Post by Moonibopper »
Kudos to everyone and to bajaman! This thing fired up the first time and sounds absolutely phenomenal!!!
tremelo68
Post by tremelo68 »
Built the klone and it sounds sooooo good. Played it in band rehearsal tonight and it really shined. Got lots of compliments tonight.
Thanks very much for sharing this pedal.
andregarcia57
Has thanked: 50 times
Been thanked: 96 times
Post by andregarcia57 »
rusty_pinto wrote:Ok, i built one. I used the May '08 schematic and parts list, but i did my own layout for a 1590BB.
Guts
Voltages check out great: putting in +9.5VDC gives -9.4VDC at the charge pump inverter pin, and +17.8VDC at the boosted supply output. If anyone can use the layout, i'm happy to share.
where did you get this box?
painted it yourself?
andregarcia57
hello okay guys?
I am wanting to use all 1uf and 4.7uf Tantalo for reasons of space, sonically change anything?
danielzink
Completed builds: Too many: www.danielzink.com
Been thanked: 27 times
Post by danielzink »
andregarcia57 wrote:hello okay guys?
Capacitance is Capacitance
http://www.danielzink.com
MoonWatcher wrote: Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
beedotman
Has thanked: 402 times
Been thanked: 393 times
Post by beedotman »
:lol: :thumbsup
andregarcia57
Are there any changes to make if I replace ICL7660SCPA by Max1044CPA1120?
beedotman
Post by beedotman »
maybe TC1044SCPA
devastator
Been thanked: 22 times
Post by devastator »
andregarcia57 wrote: [ Image ]
[/quote]
Where did you get the PCB ? seems really nice (love when pot are directly soldered on the PCB )
Would be possible to have the dimension of the PCB posted on the first post ? the scales represented on the sides are in inch or cm ?
pakrat
Has thanked: 17 times
Been thanked: 40 times
Post by pakrat »
Hello everyone, I have been reading this thread for months and finally got around to building one of these, but have not had much luck getting it to work properly. I have read through this thread a LOT, but unfourtunately it didn't help me debug my build so here I am.
I built the smaller version that Olegator had posted on page 20 with all part values from bajaman's V2 layout. The problem is that I get audio in bypass but I only get a clean boost when engaged, there is no gain whatsoever. The controls seem to work as they should... the tone pot adds treble, the volume works, but the gain just makes my signal louder without adding gain.
I have looked the board over for cold joints and bridges but it's all OK. I originally had this wired to a DPDT footswitch but changed that to a 3PDT thinking the switch wiring or the switch itself was the culprit, but still no gain. All of my diodes have the bands facing the + and I have also double checked all component values.
I used two TL072CN opamps and my charge pump is ICL7660SCPAZ. Supply voltage is 9.50v and I am getting 17.23v off of the second IN4001 diode. If anyone can spare some time to help out with this, I'd really appreciate it!
Here are my voltages:
IC1 (Top left TL072)
1 4.72
2 4.74
3 3.74
4 0.00
5 4.73
6 4.75
7 4.75
8 9.50
IC2 (Right side TL072)
1 4.72
2 4.74
3 4.74
4 -9.15
5 4.74
6 4.74
7 4.76
8 17.24
IC3 (ICL7660SCPAZ)
1 9.50
2 4.75
3 0.00
4 -9.15
5 -9.15
6 5.06
7 7.45
8 9.50
Thanks in advance to anyone who can help, and a big thanks to bajaman and everyone who contributed to this awesome project!
I would be checking your wiring of the ganged volume potentiometer - from what you are describing you are only getting the clean boosted section working and nothing from the distortion stage :wink:
Your Op amp voltages are correct - are you using the correct value resistors in the gain stage :?: (the one with the clipping diodes after it :wink: )
I cannot vouch for other peoples layouts, but MANY folks have built my layout without any troble - check again :!:
pakrat
Post by pakrat »
Thank you very much for the reply bajaman. The layout I used is almost exactly the same as yours and I used the same values. I have been suspecting offboard wiring as well because with an audio probe I can hear the clipping all the way to the wiper on the volume pot. I use a test tone generator to audio probe because it's easier than playing.... maybe that's not a good idea.
I have my gain pot wired like this:
I don't have the 15k resistor in parallel to the 82nf cap either because I didn't see it listed on the V2 layout that I have, do I need it?
