BAJA Sagittarian Charger (mini KLON)  [documentation]
danielzink
Completed builds: Too many: www.danielzink.com
Been thanked: 27 times
Post by danielzink »
pakrat wrote: I don't have the 15k resistor in parallel to the 82nf cap either because I didn't see it listed on the V2 layout that I have, do I need it?
It's already there....
Look at the 82n on the layout and note the 15k sandwiched right next to it - and the traces that connect them (v2)
Dan
http://www.danielzink.com
MoonWatcher wrote: Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
pakrat
Has thanked: 17 times
Been thanked: 40 times
Post by pakrat »
Thanks Dan, I didn't even notice that :oops:
pakrat
Post by pakrat »
I just went through with an audio probe and I don't get clipping anywhere, even on the 1N34A's themselves.
check the value of the resistors associated with the gain stage op amp (the one that drives the clipping diodes) :wink:
R6, R10, R11, R12, R13
ALSO
Check that you haven't got a solder bridge between the pins 6 and 7 of the op amp :hmmm:
pakrat
Post by pakrat »
Thanks again for helping bajaman. All resistors checked OK and I found no solder bridges anywhere on the board. I also have tried different TL072's and there is no change.
Okay - post some hi res pictures then (both sides of board please)
pakrat
Post by pakrat »
Here are some pics. I apologize for the quality.... looks like it's time for a new camera.
apollomusicservice
Has thanked: 64 times
Been thanked: 819 times
Post by apollomusicservice »
to "pakrat", check R2 on your board. It seems to me that is 10k and it should be 1M. :hmmm:
pakrat
Post by pakrat »
apollomusicservice wrote:to "pakrat", check R2 on your board. It seems to me that is 10k and it should be 1M. :hmmm:
Checked R2 and it is 1M, thanks for the input though :thumbsup
please provide a photo showing the gain pot to the board connections :wink:
pakrat
Post by pakrat »
Here s the gain pot wiring.
The orange and white wires on the left are going to 3a and 1a respectively. The next 3, orange, white, and green go to 3b, 2a, and 2b respectively. Then there is a link from 2a to 1b. The wires have taken a little beating from trying the different diagrams floating around. :blackeye
Okay - I can see the problem now :wink:
Move the orange wire (top left on back of pot) across to the far right terminal of the pot (where the link wire is presently connected incorrectly), and now connect the link wire to where the orange wire was previously connected on the rear section of the ganged pot. :thumbsup
pakrat
Post by pakrat »
Ok, I swapped the link and orange wires which now makes the pot work in reverse.... I still have only clean output.
picture again please :wink:
pakrat
Post by pakrat »
This wiring makes the pot work in reverse:
okay - it works in reverse - not a problem - put the wires (and link) back how they were and then swap the orange and white wires on the other pot wafer.
pakrat
Post by pakrat »
I put the link and wire back, pot works normally now. Swapped orange and white on gain pot "A" and it's still clean signal only. Are there other diodes I can try besides 1N34A to rule them out as a problem? I really appreciate you putting in time on this bajaman.
pakrat
Post by pakrat »
I still have failed to figure this thing out. After checking every component I thought I had the answer in that I used non polarized 1uf electros because it was all I had at the time. I have since replaced them with polarized electros and it remains the same.... just a clean boost. I measured the voltage at the diodes and I get 0.7v which, if I'm not mistaken, falls within the parameters of the forward voltage, yet no clipping. So I removed the diodes and measured. I get 4.5v but if I leave the probe on there the voltage drops until I remove the probe and it will build up again. I understand that sometimes a build probably can't be debugged, and I appreciate everyone who tried to help. I have decided to build the official bajaman V2 just to have a Klon, but I still would love to find out what went wrong with this thing. Thanks again for this project, and your help bajaman!
gilmour_pugliese
my favorite amplifier: DIY Hiwatt DR504
Post by gilmour_pugliese »
Just found some OA-5 black glass diodes from the '50s...
http://www.radiomuseum.org/tubes/tube_oa5.html
Their V-drop is just perfect for a good Klon-e :horsey:
Also, I own about 100 OA-95, but the range is from 0.60mV to 0.72mV, just too high for a Klon, or not?
BQmusic
Completed builds: Germanium, silicium, Bonamassa Fuzzface, SHO, Klon Centaur, Dumbbell, Flipster, Univibe, Wooly Mammoth, SVTDI,
Post by BQmusic »
While building a Klon clone on perfboard i couldn't help noticing that on the Saggitarian Charger PCB C6 and R9 have switched position as to the schematic. I presume they are part of the mid filter. Could this make a difference in sound or not?
I swapped them anyway and my Klon is working perfectly:-)
