Also Attached a Quick View of the first Version of the Clock-Section Board. I´m gonna make this Modular so i don´t end up with a giant board, and also because the Divisor Sections are all the same...
Ben
e45tg4t3 wrote:Ok thank you, i just never have seen this type of output boost.. Every Day something new to learn..
Ben
Here 'tis - COPPER side.jaidee wrote:Hi Julia
Thanks for the great post.
I'd still be interested in seeing the original PCB artwork if you can find the time to scan and post it.
Thanks, jaidee. I haven't laid hands on a Clockworks in 20+ years, but just the other day I was reverse-engineering a commercial e-drum brain, trying to establish the exact level at which it triggered. I got it just on the threshold, and there it was - the Clockworks effect! sometimes it would fire and other times it wouldn't, but always in sync with the master clock I was feeding it, making nice polyrhythms. It was so soothing I left it on at a low level all day while I worked, and it reminded me why the Clockworks is so cool. I really should build one sometime...jaidee wrote:Julia, thanks for taking the time and trouble to dig out and post the schematic.
Amongst all the postings on this board this is a fairly unique pedal and circuit, so I feel that we're privileged that you, the designer, have had the generosity and good grace to share the details!
Thank you so much for your detailed answer! It's really helpful to get this circuit laid out in such detail. To be honest i still can not completely grasp exactly what happens, but i am getting closer hehe Might also have to read up on charge pumps and such.JuliaDee wrote: ↑19 Sep 2022, 10:35 Mouser currently has 40 different 15UF 16V MLCCs in stock, 4 of which are ±10%. MLCCs are inherently low-leakage, but they do suffer capacitance reduction with DC bias, so use the largest package possible and X7R dielectric to minimize this effect. There are also many 15UF tantalum caps available.
It is the ratio between the 1UF charge-pump input caps and the 15UF staircase caps that's important. Each step of the staircase on the 15UF cap will be Vclock * 1UF/15UF.
In reality, it will still work if the ratio is off or the caps leak, you just might not get evenly-spaced divider ratios or the full range of division on the divisor pots.
The clock buffer transistors should not be too critical, but they should have a decent current rating, especially if low-ESR caps (MLCCs) are used for the 1UF current-pump input caps, since the instantaneous current required to charge and discharge all the caps may be rather high. Their beta needs to be such that multiplied by the clock opamp's output drive capability the output current is sufficient to make a decent square wave when charging and discharging all those caps.
What i mean is that the status LED instead of blinking on every X step of the clock, is just constantly on. I double checked the diode (and any diode for that matter), and i am sure it is just like on the schematic. I checked two places in the circuit with my scope and attached photosYou say that when the divisor pot voltage is 7V or less, the "output is constantly on" - do you mean the output of the comparator? That would suggest that the reset circuit isn't working - are you sure you have the reset diode going from the clock to the reset comparator's input capacitor?
