Dunlop - JBF-3 Joe Bonamassa Fuzz Face [schematic]
here are some pictures of my JBF-3 clone and self made PCBs.
About the sound of the Fuzz I can only say: IT'S AMAZING!!!! I love this pedal so much! You can get so much different sounds using your volume and tone control on your guitar! Now, I know why Joe Bonamassa never plays his Les Paul with volume and tone at 100%. You can get much more cool sounds if you try different volume and tone settings in conjunction with this Fuzz pedal!!
Thanks guys for the schematics and reviews!
P.S. I have bought about 10 pcs of my self made PCBs and if anyone needs one then send me an email (the email is on the bottom side of my PCBs -> see my pictures).
Regards
Walter Craffonara
Regards
Walter Craffonara
- DrNomis
- Has thanked: 98 times
- Been thanked: 278 times
Going to see if I can buy some GT308A transistors off eBay as I haven't really played around with these devices before.....
here is the manual of my JBF-3 Clone: https://www.dropbox.com/s/pw9sw8noamni9oy/JBF-3.pdf
The JBF-3 Clone also includes a Millenium bypass circuit to control the LED using a DPDT switch!
Regards
Walter Craffonara
Regards
Walter Craffonara
- DrNomis
wcraffonara wrote:Hi,
Regards
Walter Craffonara
Cheers, I downloaded a copy of the manual, I just recently bought a set of 5 GT308A transistors off eBay, these should work shouldn't they?.....
what do you mean with "flipping the circuit"?? The millenium circuit as described in my document works perfectly!
Hi DrNomis,
the GT308A is pin-compatible to the 1T308B but they have different specs. Probably they will also work, but I haven't test it yet.
- Seiche
Flipping the circuit as in switching gnd and supply, so that you can use a positive voltage with pnp ge trannies.wcraffonara wrote:Hi,
Oh, yes, that works!
Hi, unfortunately I still didn't find an alternative for this mosfet with the same package. If you need a ZVP3306 then send me a PM.
- DrNomis
Just received my set of 5 GT308B transistors in the mail and have tested them all with my Semiconductor Component Analyzer, what really surprised me was that they all exhibited zero leakage current which is surprising since they're PNP Germaniums, the Hfe's I measured were 35,36,40,44, and 75, I've decided to use the 75Hfe transistor in my Rangemaster pedal as it seems ideal....
On my GT308B transistors there's a small mark on the flange near one of the leads, according to my Analyzer, this indicates the Emitter, so the pinout goes E,C,B with the C lead being the one in the centre connected to the metal casing....
Hope any of that info is of use to you all.....
- Rocket Roll
I was trying to decipher the resistor values in Joe Bonamassa's personal Fuzz Face, as seen on page 6 of this thread. This is what I came up with. Only two differences look crucial to me: bigger resistor between the trimmers (ie. between the two collectors), which is mentioned in "Technology of Fuzz Face" as a way of increasing gain, and a bigger feedback resistor (between the base of Q1 and the fuzz pot), which... does something, right?
Have I read the values correctly? Original photo is on the page 6.
1T308В is latin 1T308V МП39Б is latin MP39B ,JEM wrote:Hi all, sorry to disagree with you Bancika.
But the picture that hung Tonetweaker companion is perfectly written in Cyrillic reads 1T308B if you look at the datasheet to publish on the front page of the transistor that there are three versions the terninada in A with a gain of 25-75, the model b with 50-120 and models
1T308B should be between 80-150.
I searched for information about the 1T308V and in any case is similar to that model B.
Which leads me to assume that the transistors that were of poor quality conseguistes or worse, labeled wrong.
Regards
PS: Sorry for my writing, unfortunately I do not fight well in English and use a translator.
- my favorite amplifier: VanWeelden, Marshal, TwoRock, Dumble
Greetings,
There seems to be a lot of debate over the last few years on the exact values of the components. I just wanted to ask if there is a definitive list of exact components and their correct values for the JBF3 pedal? I would love to build one.
Thanks for any help or insight that can be provided.
- Rocket Roll
Rocker83 wrote:Can anyone decipher the correct values and types of resistors and the capacitors in this JBF-3?
