Kingsley - Minstrel  [traced]
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
http://www.kingsleyamplifiers.com/jester/minstrel.html
Sound pretty bad-ass, and the build quality looks really solid.
Snagged this photo off TGP.
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
It's a stripped down version of this: https://www.freestompboxes.org/viewtopic ... t=kingsley
IMO it's a lot of pedal for the price.
Great build quality and sounds.
mmolteratx
Has thanked: 93 times
Been thanked: 618 times
Post by mmolteratx »
Here's my gut shot:
And a preliminary schematic minus switching, pots and power supply is attached.
schematic removed - new schematic is below
mmolteratx
I believe this is the whole thing, though the power supply looks a bit odd to me. The resistor labeled ??? is a metal oxide with grey-brown-gold-gold.
Mod edit: old schematic removed
WhiteKeyHole
Has thanked: 24 times
Been thanked: 219 times
Post by WhiteKeyHole »
I don't know if I'm just misunderstanding your drawing but the switching seems suspect.
mmolteratx
That's just a drawing of how things are hooked up to the switch. It's got 3 positions. In position 1, the two left lugs are connected, position 2 the two middle lugs are connected and position 3 the two left lugs are connected. I'll get bigger pics tomorrow if you want to look them over.
WhiteKeyHole
Are you sure that the 82K does not go to the middle two lugs (connected) on "top"?
mmolteratx
Actually, scratch that. The leftmost bottom lug is connected to the lug second from right in that row rather than directly to ground.
mmolteratx
Nevermind. That wouldn't make a difference. I just opened it up and it's connected as you described. New file attached.
Kingsley Minstrel.bmp (385.06 KiB) Viewed 5677 times
WhiteKeyHole
Yeah, makes more sense now. Good work and thanks!
bubstance
Has thanked: 75 times
Been thanked: 116 times
Post by bubstance »
mmolteratx wrote:The resistor labeled ??? is a metal oxide with grey-brown-gold-gold.
8.1R?
mmolteratx
That seems about right. It just needs to drop the voltage down to around 6.3V for the heaters. With 600ma of heater current for 2 12AX7s it should be around 8-10 ohms I think. Thanks!
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
mmolteratx wrote:I believe this is the whole thing, though the power supply looks a bit odd to me. The resistor labeled ??? is a metal oxide with grey-brown-gold-gold.
The resistor looks like 8.1 ohms.
vai0306
Post by vai0306 »
please,
-could you tell me where to be connected v1 and v2?
-what kind of switch?
thanks 1000
Frabbio
Been thanked: 95 times
Post by Frabbio »
Hi guys, i've developed a layout with tubes and trafo onboard for this pedal, but i still have some uncertainties:
the trasformer is 2x115 in series and 2x7 in parallel? Is this made to have a greater anodic voltage?
The switch is a 2P3T?
However here is my layout for EAGLE cad
http://www.megaupload.com/?d=ZOES85FF
Frabbio
Post by Frabbio »
Hi there, i revised the pcb, which is now 10.3 x 10 cm single sided, and i decided to use the pcb version of the original transformer (talema 70100).
Aparts from pots, jacks and switches, everything else is on board. Corrections or suggestions are welcome.
Schematic+ layout rev4
http://www.megaupload.com/?d=AWE5SZ70
mmolteratx
Wow! That's awesome.
looseEelBalls
Post by looseEelBalls »
good job on the artwork!
I have a couple of concerns on the layout, however. With the toroidal transformer being placed where it is on the PCB layout, wouldn't you have noise issues with transformer flux interfering with the preamp tubes? Also, I'm wondering about the heater supply. Any thoughts about noise from the turret/point to point/handwiring crowd?
Frabbio
Post by Frabbio »
I decided to make this layout because i've almost filled my pedalboard, and i can't assure it would not be noisy. Toroidal transformer flux is for the most part confined inside, but in case it hums nothing says it can't be separed from pcb :) . Imho building on pcb is the better solution for noise, but it surely doesn't have that unobtainium mojo thing :lol:
Your concern about the heater supply is regarding noise or something else?
mmolteratx
Hmm. There might be issues with the heater wiring. You might have to rectify and regulate them or modify the routing. I just mod amps though so I'm not sure.
