5 pin connect jack/plug
- Beedoola
I'm planning on doing a DD-5 mod that involves an external control switch which will need 5 wires hooked up - two for tap tempo, and 3 for a TRS hook up to select modes.
I don't want to drill another hole into the chassis for the TRS - since the DD-5 has the stock Tap In. I want to remove the Tap 1/4 and install a 5 pin plug that can take care of my needs: What are my options? I don't know the technical names of other jacks. Would a midi work? What else is there? Also. It would be something where I could find a right angled male plug to go into it - the pedal resides between others and it would be a pain to have a straight male plug going into the side of the pedal.
Thanks.
Thanks.
- Hides-His-Eyes
Some kind of computer connector? It's such a tiny hole. Too small for a MIDI.
- Hides-His-Eyes
I'd just send a cable out and use a breakout box myself.
I would use an RJ45 if possible. About the right size, 8 conductors, cables are easily available in different lengths and are easy to replace. The cable terminal is also contained inside the jack, so you don't need to worry about anything sticking out of the pedal.
