Quite obviously some of you folks just don't do a lot of *Real World circuit
testing*?
Just build the classic TS9 circuit and delete the humble BJT buffer and run the
signal directly to the opamp. Replace that 10k input with a 1meg R,,, Have fun with
the resulting noise. Winky.
Even though I have done this many times I'll be a mug and test it all,, yet again.
Just came back from the shed and worked it both ways.
I then simulated the results for you.
1/ The circuit with no buffer is as noisy as hell.
2/ Added the buffer as shown and the noise is no issue at all.
So Go figure?
Sadly you will have to do the hard yards if you want to hear it for yourself as
simulations don't do actual sound very well. LOL
Sorry if I'm not much good with math’s (It's only a hobby for me) but I have worn out 3 bread boards over 30 years muckin about with all these supposedly wonderful text book circuits that just plain Don't work.
Some text book stuff is smack on but you gotta read between the lines for the hidden
tricks.
Rather than me trying to Ezzplain it all, go look at *Mesa Vtwin* schemo.
Now delete all those buffers that the casual observer might see as pointless.
Get back to me with your noise results. Winky.
You will have one hell of a noisy circuit without those buffers after the tone
stack. (Note the use of 10k/10k Voltage dividers)
From memory there was some good comments on noise issues in *Art of Electronics*.
Even after lots of reading such books it took me many years to grasp the hidden
secrets of getting around noise problems.
All that one line *Fundamental Rules* stuff comes from the HiFi school of thought
where everything is an *Ideal* circuit.
Sadly Guitar circuits are worlds away from the ideal fantasyland of that flat 20/20
bandwidth when using DC coupled Low Z circuitry. (So perfect, beyond belief)
That *Perfection* is part of the reason why SS circuits often sound so crappy for guitar.
It's not so much a SS problem but more about circuit design which has more to do with those things called Resistors/Capacitors than the mojo of matched Valves or exotic opamps with zero noise figures.
Even if your opamps where made by God,, if the circuit design is crappy,,,
well you just have to wear the noise/hiss as well.
@ *k1rkyd*
A Word of advice;
Go get yourself a breadboard and build yourself a few circuits before you commit to
stuff. In the long run you will get there faster and you will also KNOW WHY it
works. (or the more likely outcome,,,does not work??? bugga)
Side note;
Notice how the buffer dramatically improves the low freq response even though I have not altered the components. You don't need to use buffers but if you want max performance and lower noise,,,use buffers.
Another small subtile point the use of series R does help wipe off extreme high freq which in most cases will be more pleasing to the ear.
The closer you get to pure DC coupled HiFi type circuitry the worse it becomes for guitar. to much high freq just destroys great OD guitar sound.
@ *earthtonesaudio*
Sorry I don't get it?
I assume you have used the second part of an 8 pin opamp to improve the bias voltage but the circuit is still potentially noise prone. Where is the benefit in that?
Anyway I've done my bit. I've retested what I already knew to be so.
What others do is up to them.
I have no doubt there are better circuits than mine but I've not as yet found them.
Cheers to all, Phil.
