What did you do on Boxing Day - I built a pedal from scratch - okay , I had worked out the board layout and PCB earler, with help from More Cowbell and Super Velcro Boy etc., but never got around to building it - curiosity got the better of me and I realised I could fit it in a 15090B case quite easily - 4.5 hours later and here is the result
I did not use the fancy dpdt relay switching - I used the 3pdt blue new sensor switch and wired it for true bypass.
notice the last picture of the baseplate - there is a sheet of clear mylar film attached to the inside to prevent the circuit board from shorting out, and notice the flange filed off on the bottom corner - saves mutilating the 9v battery case.
As usual no sound samples - my guitar playing is shocking
, but how does it sound - WELL - i was amazed - the bottom end is round and full and it does not turn to mud when the fuzz is turned up - say what you like about noisy LM386 power op amps but they are the closest I have heard to a good tube amp overdrive - definately not a Tube Squealer clone and worthy of further study by yours truly
A truly Great design from Fran
- I have never heard a 9v pedal with this lush a bottom end - seriously folks
Well worth the effort building this baby - I used MKT 100v film caps - Fran uses high voltage tube amp caps in her pedals - I do not know if there is any sonic difference, but I am more than happy with my non mojo build.
