Tube overdrive kit... in tag board??
Posted: 09 Apr 2011, 20:01
by Duckman
Re: Tube overdrive kit... in tag board??
Posted: 10 Apr 2011, 11:12
by DrNomis
For a tube based pedal running on only 9V, it sounds surprisingly good, I expected it to sound really gated, wouldn't mind buying one of those kits....
Posted: 10 Apr 2011, 18:22
by ppluis0
Mmmmmmm.....
At first sight, judging for the components included in this kit, I guess that is merely a valvecaster but with the addition of a preceeding stage with a fet booster.
Count the parts in that picture:
Also, several users reports that achieve best sound after replace the tube with a 12AU7 (ECC82 in Europe), same as the valvecaster.
The funniest thing of this kit is that they provide the battery clip...
The heater inside this little fella, that normally use 12,6 V and 150 mA, take 127 mA @ 9 Vdc, so a fresh 9 volt battery must drop dead in the middle of a rehearsal...
Posted: 12 Apr 2011, 01:57
by ppluis0
Another image. The same pedal internal view, mounted according the instructions of the seller:
Posted: 06 Feb 2012, 01:49
by ppluis0
Bump an old thread again...
There is an explanation about this kit and the schematic is revealed also:
http://www.guitarkitbuilder.com/content ... rive-pedal
Enjoy,
