Lovepedal Karl Fuzz.  [traced]
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
Ups, the layout has an error: The output cap (C5) must be connected to the collectors, not the emitters. Quick and dirty workaround: Desolder the upper leg of C5, pull it out of the hole and connect it to hole f7 with a piece of stranded wire.
kinski
Has thanked: 10 times
Post by kinski »
NICE! Works beautifully now. Pretty cool fuzz. I think I'll give it a 1590A for a home! Thanks a ton roseblood11! :hug:
roseblood11
Verified version...
I changed the power supply filtering to match the schematic. Shouldn't make any difference...
johnk
Has thanked: 36 times
Been thanked: 293 times
Post by johnk »
if anyone's interested here's a verified PCB layout for etching that I built of it:
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
A very significant improvement - change the input pot for either 100k or even 500k. This raises the input impedance a lot, and makes the pedal respond better to the guitar controls. It becomes very much "brighter" too so I put 15n across the output pot. It's probably not the way the thing was meant to work, but if the input level is just right, you can get some nice octave effects going on.
Thanks Chris. 15nF seems to be hell of a lot
johnk
Post by johnk »
i'm digging mine just the way that it is with my P bass.
johnk
Post by johnk »
i mounted mine in a 1590G:
