Retro Channel - The Fuzz  [traced]
marshmellow
Has thanked: 19 times
Been thanked: 126 times
Post by marshmellow »
Had a bored, rainy afternoon yesterday.
Attached is a pcb layout, I used the revised cap values.
Should fit a B-type enclosure nicely with pcb mounted pots.
Retro Channel, The Fuzz.pdf
(181.12 KiB) Downloaded 996 times
Desdog
Has thanked: 62 times
Been thanked: 16 times
Post by Desdog »
marshmellow wrote:Had a bored, rainy afternoon yesterday.
Great, business as usual!!
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
based on marshmellows schematic
btw: it's interesting that ibodog contributed a lot to this thread. Conspiracy...
I'm looking into where the rest of the thread went.... I honestly don't know
tube-exorcist
Has thanked: 173 times
Been thanked: 67 times
Post by tube-exorcist »
Unfortunately the picture of the chinese Recto-Chanel clone has been lost. Here it is again:
GuitarlCarl
my favorite amplifier: anything tube
Completed builds: Ds-1 mods, SD-1 mods, Small Clone mods, Muff build, Axis build, various other transistor booster builds... I can build a badaxe harmonic perc, but I can't get a fuzzface to sound worth a crap!
Has thanked: 54 times
Been thanked: 29 times
Post by GuitarlCarl »
Ok so I'm guessing all the tranny's in an array have equal hfe's... So, is D1 in the schematic fooling the tranny into thinking it has a lower hfe, or acting like a lower hfe transistor? I think the first transistor in a tonebender is lower hfe too correct?
iq01221
Has thanked: 31 times
Been thanked: 8 times
Post by iq01221 »
tube-exorcist wrote:Unfortunately the picture of the chinese Recto-Chanel clone has been lost. Here it is again:
:applause: :lol: :mrgreen: Jajajajajajajaja!!!!!!!!!! Now with rat urin smell!!!
juanro
Has thanked: 51 times
Been thanked: 117 times
Post by juanro »
GuitarlCarl wrote:Ok so I'm guessing all the tranny's in an array have equal hfe's... So, is D1 in the schematic fooling the tranny into thinking it has a lower hfe, or acting like a lower hfe transistor? I think the first transistor in a tonebender is lower hfe too correct?
Seems to me that D1 is in the opostite direction of the PN junction of the first transistor... is there either as an input protection (?) or to clip negative peaks of input signal and avoid the base of the first transistor to drift too negative (??)
Regards,
Juanro
juanro
Post by juanro »
Hey,
Someone asked for our own artwork, here's mine:
Juanro
Tonetweaker
Has thanked: 23 times
Been thanked: 58 times
Post by Tonetweaker »
juanro wrote:Hey,
Juanro
Couldn't add a thanks (error message)... so I'll do it this way:
THANKS! :thumbsup
Cheers...
Steve
In Soviet Russia, dirt box fucks YOU!! ~ Seiche
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
juanro wrote:Hey,
Juanro
I still reckon that Q1 and Q5 are some kind of voltage divider biasing system for Q2, though the need for it to be as complex as it is sure is a mystery, you could probably achieve the same effect by substituting plain vanilla 1N4148 Si diodes for Q1 and Q5, well I'm going to try breadboarding the circuit when I have some spare time, and I'm going to do some analysis of the circuit and try and see if I can work out exactly how it works, hope you don't mind juanro.... :thumbsup
juanro
Post by juanro »
I don't mind at all, au contraire, but sure know someone that will... hehe.
Juanro
Post by DrNomis »
juanro wrote:I don't mind at all, au contraire, but sure know someone that will... hehe.
Juanro
Lol...I can only guess.... :lol:
I'll make sure I post my findings in this thread for the benefit of all FSB members then...cheers.... :thumbsup
mganzer
Has thanked: 32 times
Been thanked: 26 times
Post by mganzer »
ca3086 subs ca3046?
juanro
Post by juanro »
Datasheets looks very similar:
CA3046: http://www.intersil.com/data/fn/fn341.pdf
CA3086: http://www.intersil.com/data/fn/fn483.pdf
Same pinout, Hfe, Vbe, and pretty much the same parameters in general. Take a look (a more detailed one than I did) to see if you can spot some difference.
Regards,
Juanro
mganzer
Post by mganzer »
Yep Juanro, is pretty similar with slight differences...
i guess a try this one (dificulties to encounter 3046 in Brazil).
thank you for help!
mictester
Been thanked: 825 times
Post by mictester »
mganzer wrote:Yep Juanro, is pretty similar with slight differences...
thank you for help!
The 3086 has higher Ft transistors. This is only really significant when you get to VHF, so you really don't need to worry at audio frequencies. I used to find that the hfe of the transistors in the 3086 was slightly lower than in the 3046, but only by a very small amount.
Post by DrNomis »
I've got ten LM3046N ICs in front of me sitting in some black conductive antistatic foam as I type this.... :hmmm:
mganzer
Post by mganzer »
Thank you guys mictest and juanro for the great help and very nice job on this little nice box of love and dirt fuzz... I hope it sounds close to the Tone Bender mkII it's really a wonder (with three selected oc75) whose only problem I see is the ground positive ... I ride this more as a matter of saving tbmk2 of continuous use ...
DrNomis wrote:I've got ten LM3046N ICs in front of me sitting in some black conductive antistatic foam as I type this.... :hmmm:
Put it in a box and rock it! yeahh :horsey:
Steven_M
Has thanked: 59 times
Been thanked: 35 times
Post by Steven_M »
Excuse the tuning and playing.
Guitar is a tele, amp is a Pro Junior.
This fuzz is huge! you need to build it. I can't comment on how close it sounds to an original, either tonebender or Retro Channel, but it sounds good!
