fakcior wrote:Use of the diodes make different opamps sound more similar, but it doesn't mean they sound the same.
Well, the diodes are compression limiting/clipping or soft clipping to a point, and up to that point they are still retaining much of the input signal that is fed to them from the Opamp. It is not until the peaks square off that Hard clipping begins making different Opamps sound similar. I find the beginning of this threshold to be around the half way spot of the Distortion potentiometer with the Volume potentiometer full on. And with stock cap and resistor values as well as stock 1n270 diodes, this threshold is dictated by the Opamp used.(I demonstrate this below) The point is, the vintage 741CP, UA741CP are different then the LM741CN even though the spec sheets may state they are exactly the same. Yes, other type of single Opamps used within this circuit will sound different, however, the same is true with the different 741's used in the original Script and Box logo'd MXR Distortion+'s. Although you may have to strum something other then an open G chord to actually hear or feel the difference.
(Note: My Favorite's were the Original 74 Script 741CP chip and the LF356)
TL071
LF356
LM741CN - company A
LM741CN - company B
UA741CP
741CP - Original 74 Script chip
~waldo
