Duel footswitch wiring problem
GiAnt_ROboT
Post by GiAnt_ROboT »
Hey guys,
I'm building a Devi Ever Shoegazer with a couple of her kits. Its two fuzz circuts in one box. The Soda Meiser going into the Torn's Peaker.
So heres my problem. I wired both of them by themselves and they both work fine but when I wire them in series I get nothing from the Torns Peaker side. The weird thing is when I touch the lugs on the back of the footswitch the signal starts to fade in and it starts to work. Any ideas of whats going on here? Any help would be much appreciated.
Grendahl
Been thanked: 7 times
Post by Grendahl »
Make sure you've wired them up similar to the diagram from the link below:
http://www.generalguitargadgets.com/pdf ... a841b3e85a
Also, make sure they both work individually before trying to box them both in one enclosure.
Resistance is futile...
( if < 1 ohm )
