Here's a vero I did for a silicon fuzzface I built recently:
It's essentially a Lovepedal Dragon/BBB etc etc, which is just a fuzzface with an input cap blend. I made the bias trimmer into an external pot, because I wanted to be able to dial in that glitchy, kitchy, misbiased sound occasionally: Here's the original trace of the Lovepedal that Greg_G did (thanks Greg!) -
https://www.freestompboxes.org/viewtopic ... =lovepedal
It's pretty tiny (9x9 holes) and so should easily fit in a 1590A, if you are that way inclined: I stuck it in a 125B which looks huge compared to the board:
edit:
ps - transistor pinout is CBE from top to bottom
Silicon Fuzzface Plus+ - Tiny veroboard layout
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
