Mad Professor Ruby Red Booster
that's a lot of parts for a booster... intriguing. :hmmm:
coldcraft
Has thanked: 38 times
Been thanked: 84 times
Post by coldcraft »
well, its two things in 1. like me, I'm a man, and a provider...
MoonWatcher
Has thanked: 40 times
Been thanked: 52 times
Post by MoonWatcher »
RnFR wrote:that's a lot of parts for a booster... intriguing. :hmmm:
That was my first thought, too.
I guess that a booster now has to be more than just that, at this point. Buffers and tone shaping seem more and more common.
coldcraft
Post by coldcraft »
I have not really listened to this pedal before, but I'm pretty interested in whatever it might be.
Judging by the number of gain elements, I'm going to suggest that 1 transistor might be for driving/switching the LED, and that the switchable output buffer is opamp based.
That leaves 1 opamp stage for a boost, and 3 FETs. From reading about its operation, it sounds like turning the treble boost knob down removes the bass cut. That has me thinking that the Treble Knob is actually a blend between flat and treble boosted signals (50kB). We could assume that it is a FET based treble booster perhaps. Also, we probably shouldn't rule out the idea that some FETs could be used for clipping, as we've seen that before in the Sky Blue OD.
just my thoughts.
coldcraft
Post by coldcraft »
so thats a single opamp, the 5534?
WhiteKeyHole
Has thanked: 24 times
Been thanked: 219 times
Post by WhiteKeyHole »
Yes.
coldcraft
Post by coldcraft »
ok, well that helps us narrow down the possibilities. Seems like it has to be 2 JFET Boosters with an OpAmp Buffer.
WhiteKeyHole
No need for speculation. I'm tracing it now.
WhiteKeyHole
So, yeah, definitely need some confirmations before I'll post the schematic but the buffer is very similar to the "Folk Buffer." The "booster" is a typical cascaded FET design in four stages.
coldcraft
Post by coldcraft »
WhiteKeyHole wrote:No need for speculation. I'm tracing it now.
but speculation is so fun! what happens when I'm right without ever seeing/hearing a ruby red! I will be da bwoss.
anyway, perhaps one of the FETs is an input buffer?
WhiteKeyHole
coldcraft wrote:anyway, perhaps one of the FETs is an input buffer?
Not strictly speaking, no. It's all traced, I just need some of the electrolytic and monolithic capacitor values and confirmation on the "Treble" control, as the relevant traces are hidden.
Anyway, like I said, four stage cascaded FET design. 1 > Treble > 2 > 3 > Boost > 4 > Master. The IC buffer, when engaged, is only active in bypass.
four stages for a booster? that thing must be loud and clean. either that, or it can get dirty as well. is this really just a booster, or a FET OD as well?
coldcraft
Post by coldcraft »
RnFR wrote:four stages for a booster? that thing must be loud and clean. either that, or it can get dirty as well. is this really just a booster, or a FET OD as well?
from the description, it does distort when the gains are up and the master is down.
WhiteKeyHole
Awesome, thanks. Yep, that confirmations what I have drawn.
WhiteKeyHole
As always, there may be revisions. The switching scheme I have shown may not be accurate insofar as specific methods are concerned (ground input in bypass, etc), but will provide the same basic functionality.
coldcraft
Post by coldcraft »
that's quite interesting. I have never seen FET stages like that, which more-or-less equal Drain and Source resistors for DC bias and then using Cap and resistor bypass to set the AC again. I will have to bread board those individually and evaluate the sound.
coldcraft
Post by coldcraft »
i forgot to ask, what's the verdict on this pedals sound? is it crunchy/grit at higher gains? smooth or harsh, etc?
Barcode
Been thanked: 32 times
Post by Barcode »
coldcraft wrote:i forgot to ask, what's the verdict on this pedals sound? is it crunchy/grit at higher gains? smooth or harsh, etc?
I'll probably find out later tonight when I whip up a PCB for this (which of course I'll share) and build it to find out. Provided I have any fets in my stock.
Barcode
Post by Barcode »
does the 2n5952 have the same common pinout as j201 and 2n5457? I think it does...
WhiteKeyHole
Yes, though they need to be rotated 180 degrees.
