Mad Professor Ruby Red Booster
- coldcraft
not that I expected it to, but I breadboarded this with 2N5457s and it does make sound, but it doesn't sound good at all. not all JFETs will bias with those resistors so keep that in mind. I wonder if MP does JFET selection or if there's something special about the 2n5952
- WhiteKeyHole
Shoot for what sounds good but I would guess that the unit has around 6.5V at the drains.
- WhiteKeyHole
Hm, figured they would have biased up similarly to the SBEQ.
To avoid confusion, the drain and source voltages should be swapped.
- WhiteKeyHole
I'd check around the Treble control first and foremost. Also, resistor values can be tricky due to lighting.
- Barcode
It could also be a biasing issue. If the schem is accurate in that 2n5952 fets were used, and the stock unit is showing source voltages around half of supply, then your source voltages are pretty high. You could need some resistor tweaking.
- WhiteKeyHole
As Barcode said, try adjusting the bias (through the source resistors) for roughly Vcc/2. That could definitely account for the 25%.
I'd check R4 and R14, though, as those were the resistors I was most unclear about.
- Barcode
I don't see any functional reason for it, the polarity is not functional in the design so you could just as easily use a film there. .47uF is a pretty damn big cap though in most non-polarized configurations. Most likely the reasoning is not to have two caps take up half the board
- WhiteKeyHole
I'm not sure about some of those values. At the right of the board, the resistor you've notated as 47k (in the black box), clearly has the markings for 1M. Also on the right, the "470k" is marked as 470R. Could you double check those, please? Thank you.
- WhiteKeyHole
Updated: Corrected resistor values. No circuit/structural changes.
- RBBR2.png (9.54 KiB) Viewed 1685 times
- IvIark
Here's a vero layout for it:
