Malekko Vibrato
KindaFuzzy
Has thanked: 74 times
Been thanked: 257 times
Post by KindaFuzzy »
Either that or it's a monolithic ceramic, I'm not sure what type the rectangular yellow smd caps are. It says 225 though.
KindaFuzzy
I tried the 22k mod last night, and worked like a charm, instant 'come as you are' tone. I've never played a small clone before, since my CE-3 was the only chorus I've ever tried and I'm not terribly fond of it. I really dig this one, nice warm tones. I might even keep it since I probably couldn't build one for cheaper. Here's a pic of the giant 1/4W resistor, and kinda messy soldering since it was such a bitch to get that resistor in there with a plain iron tip.
andrej
my favorite amplifier: Vox AC30
Completed builds: Zvex Woolly Mammoth
Boss DS-2 mod
Vox AC4
Crowther Hotcake (and own variations)
TS-808
Big Muff Russian
Big Muff IC
Superfuzz
Superfuzz
Big Muff
Mixer/Blend
various other stuff
Been thanked: 51 times
Post by andrej »
you should really make it switchable.
engineelite
Been thanked: 41 times
Post by engineelite »
Does anyone know how to mod this pedal to make the speed range a little slower? I dig this little pedal a lot but if the speed range could reach into the slower speeds it would be perfect for me.
knutolai
Post by knutolai »
Did you try increasing the Rate pot value? Or maybe substitute the 2.2u Tantalum capacitor in the LFO section.
engineelite
I haven't tried any mods yet. I'm open to anything that will lower the minimum rate. If I were to change the value of that cap then what should I change it to? Thanks.
knutolai
Post by knutolai »
caps in parallel add the individual capacitances. Try another 2.2u in parallel Im thinking that would half the rate?
engineelite
I just tried installing the 2.2T cap in parallel with the other 2.2T in the LFO section and I get some interesting results.. When I first plug in the power and strum a few chords it sounds great and it definitely slowed the rate down. But then after I turn the speed knob all the way down and come back up the entire effect of the vibrato quickly fades away and I'm left with just a "bypassed" sound. If I switch the pedal off and then back on, the effect never comes back until I unplug the power from the pedal and start over.
Any ideas?
