Silva mica capacitors
Posted: 12 May 2011, 23:56
by Drzeus
Any idea?Any use?(l-r)200+/-5 1000wv em--cd 470+/-10%--adi 27+/-20% thanks
Re: Silva mica capacitors
Posted: 13 May 2011, 05:33
by DrNomis
They're fine for use in Valve/Tube based Guitar Amplifiers....
Posted: 22 May 2011, 13:39
by Zokk
They are also very good for some crucial applications where temperature stability is required. I'm thinking about V/Oct tracking in a VCO circuit or stuff like that.
Posted: 23 May 2011, 01:57
by RnFR
Posted: 23 May 2011, 23:06
by Drzeus
Thanks everyone,i think they are silver mica(maroon colored),and I've got a better idea as to how to use them now
Posted: 16 Jul 2011, 17:31
by marsens
To my ear, the sound will have "glassy" effect.
I use them in some music application, but I don't use them in stompbox.
Posted: 16 Jul 2011, 21:44
by Seiche
Zokk wrote:They are also very good for some crucial applications where temperature stability is required. I'm thinking about V/Oct tracking in a VCO circuit or stuff like that.
or in the arsy fuss for example
edited by rocky to remove contentious branding[/i]
Posted: 16 Jul 2011, 21:52
by iq01221
Seiche wrote:Zokk wrote:They are also very good for some crucial applications where temperature stability is required. I'm thinking about V/Oct tracking in a VCO circuit or stuff like that.
You mean the MKII arsy mod
Posted: 24 Jun 2013, 05:56
by Spefinzephyr
I have a few of these lying around, picked up a few for the hell of it from PedalPartsPlus.. So am I to understand that these are not ideal for stomp boxes?
A glassy sound might actually be cool
Posted: 30 Jun 2013, 12:09
by Zokk
Honestly I'm not sure if someone is really able to hear the difference between silver mica and styroflex or regular poly film caps in most of pedal circuits.
However they can be heard easily in microphones as they are sometimes perceived as "hi fi" and better sounding compared to other caps, and that's a very good thing.
They are great capacitors in general and they often have tight specs, so don't worry about using them in any guitar related gear
Posted: 17 Sep 2013, 16:35
by oliver84
As @Zokk said, I think they are to be used in applications where things can get heated up a lot and you need some stable performance. This can actually be read from its description where it has very less values shown in percentages. These are tolerances, the deviations from actual performance with the shift in temperature. You can use them normally in any amplifier, I don't they'll give you any difference in sound unless you're amplifying only a certain bandwidth.
