Sourcing parts for Echo Base in Europe/Denmark
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
Hi all!
I want to build an echo base (http://musicpcb.com/pcbs/echo-base-delay/), and i'm having a bit of trouble finding some parts from distributors in europe.
First: the PCB is from the US, and i guess there's not much to do about that :D
Second: i have only seen the PT2399 available from smallbearelec, again in the US. (http://www.smallbearelec.com/Detail.bok?no=263)
My issue here is that for every order i recieve from US i have to pay 25%VAT (not really a problem), but i'll also have to pay a handling fee, which is around $35. That way the pt2399 alone is going to cost me about $40 plus shipping to Denmark. The PCB will be another $53 plus shipping.
Are there any european distributors who carry the PT2399?
Third: I don't know a whole lot about IC's yet. Are the following 4066 chips suitable for use in the Echo Base, and are some characteristics more important than others here?
http://dk.farnell.com/nxp/74hc4066n/ic- ... /dp/380957
http://dk.farnell.com/fairchild-semicon ... dp/1014045
http://dk.farnell.com/texas-instruments ... dp/1106112
http://dk.farnell.com/on-semiconductor/ ... dp/9664700
Also, the bill of material says "bilateral switch", and the 4066's readily availabe here says CMOS. Does that make a difference?
Fourth: How about this one for the 7805: http://dk.farnell.com/fairchild-semicon ... dp/1102157
Fifth: Transistors:
Farnell lists BC548 as a readily available alternative to a 2N5089. Acceptable?
I already have a bunch of MPSA18's lying around. Can i use them instead of both 2N5089 and BC560?
Anything else should be piece of cake :) Thanks in advance guys!
/grrrunge
Has thanked: 218 times
Been thanked: 857 times
andersom
my favorite amplifier: Valvepower 18 watt
Has thanked: 37 times
Been thanked: 7 times
Post by andersom »
You could always ask taylor if he is willing to put the ic with package.
reneshelle
Has thanked: 35 times
Been thanked: 47 times
Post by reneshelle »
I've used banzaimusic.de and musikding.de several times. They have all you need. If they should happen to be out of stock or something like that PM me and we can work something out. I think I have all you need for this build in my parts drawers. I live in DK too.
edit: I don't have the pcb. I do have a verolayout though...
LaceSensor
Has thanked: 57 times
Been thanked: 277 times
Post by LaceSensor »
Banzai will do it, also doctor tweek in the uk has the parts and ic
If neither of these work out let me know I have about five pt2399 in my parts bin...
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
banzaimusic.com has quite high shipping cost.
uk-electronic.de and musikding.de are cheaper. And quicker... And both smaller shops give better support (both at the forum of musikding.de...)
btw: the PT2399 is MUCH cheaper at taydaelectronics.com
Do you have to pay VAT in denmark for small invoice amounts? In germany, we don´t have to pay import sales tax for everything below 20€ (including shipping cost) and no duty for everything below 150€.
@reneshelle: Do you have a vero layout for the new version of the Echo Base?
reneshelle
I don't remember where I downloaded the vero. It's not mine. I've searched around to see if I could find it again, but did not find it. It looks a bit like this one
http://www.aronnelson.com/gallery/main. ... e.JPG.html
I don't know who made it, but all credits go to that person. Gila Crisis? - Is that a person?
I'm posting the vero here, but I will remove it if the person who did the layout wants me to.
I have not build it.
roseblood11
That´s the old version with the noisy input and output buffers...
grrrunge
Post by grrrunge »
reneshelle wrote:I don't remember where I downloaded the vero. It's not mine. I've searched around to see if I could find it again, but did not find it. It looks a bit like this one
Thanks! :) I'm not sure my vero-skills are that good, so i'm gonna get a buddy of mine to send me a PCB from the US. I suppose that's gonna save me some troubleshooting-time, and leave me with more time playing...
reneshelle
roseblood11 wrote:That´s the old version with the noisy input and output buffers...
Ok. The one I linked to is just the same without the tails option then I guess...
grrrunge
Post by grrrunge »
I got this in a PM from mictester - i hope it's okay i repost it here without the trade proposals.
mictester wrote:Subject: Sourcing parts for Echo Base in Europe/Denmark
This is the one to use. The 74HC version is limited to 5 V operation, and costs more. The 74HC is much faster, but this isn't appropriate for audio work.
grrrunge wrote:Fourth: How about this one for the 7805: http://dk.farnell.com/fairchild-semicon ... dp/1102157
That will be fine.
grrrunge wrote:Fifth: Transistors:
Yes.
grrrunge wrote: I already have a bunch of MPSA18's lying around. Can i use them instead of both 2N5089 and BC560?
You'll get a very slight increase in noise, but you probably won't notice it.
grrrunge
Post by grrrunge »
Wooo... Ordered the pcb's this friday, and today i got a notice from Taylor saying the boards have shipped out... I'm looking forward to this! :)
cpm
Been thanked: 50 times
Post by cpm »
7805 are big, they go up to 1A but you donr need that much
try to get a 78L05, they are TO92 package (like a standard transistor)
grrrunge
Post by grrrunge »
cpm wrote:7805 are big, they go up to 1A but you donr need that much
yeah, but aren't the 7805 the ones that are thought to be on the board, or do they have the same distance between the legs?
roseblood11
You can bend the legs of the L-version...
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
The 7805 was probably used because the board designer had plenty of them. The 78L05 will fit into the 7805 holes - you'll just have to spread it's legs a bit! :thumbsup
Useful trick with the 7805 - the tab is connected to the centre pin (ground), so if you bend the whole regulator flat to the board, you can use the hole in the 7805 tab to screw the board to the case...
cpm
Post by cpm »
mictester wrote: Useful trick with the 7805 - the tab is connected to the centre pin (ground), so if you bend the whole regulator flat to the board, you can use the hole in the 7805 tab to screw the board to the case...
...and use the enclosure as a heat sink if needed
but dont rely on it as the only support for the board to not stress solder joints
uncleboko
Been thanked: 38 times
Post by uncleboko »
I don't understand why you have to pay VAT on chips bought from the USA. Is it because they are imported to the EU? Unless you are a business, you will pay VAT on chips bought in the EU. The rules have changed recently and are very complicated.
uncleboko
Post by uncleboko »
uncleboko wrote:I don't understand why you have to pay VAT on chips bought from the USA. Is it because they are imported to the EU? Unless you are a business, you will pay VAT on chips bought in the EU. The rules have changed recently and are very complicated.
Just spoken to HMRC in the UK, it seems that the shippers pay the VAT on entry which is then passed on to the purchaser.
Why not have a holiday in the Channel Islands and have the chips sent to your hotel there - no VAT!!!
Hides-His-Eyes
Been thanked: 49 times
Post by Hides-His-Eyes »
To avoid putting british businesses at a massive disadvantage.
The reason you don't pay VAT importing from within the EU is that all EU countries have their own VAT equivalent and it's not inkeeping with the "common marketplace" to make buyers pay twice for importing within the EU.
