Can someone double-check this wiring
Lemmings
Post by Lemmings »
Another noob question! Does this look right?
I just wanted to check - I just need to tie all of the grounds together, then to the jack sleeves and then to the negative terminal of the 9v jack? And then tie all the 9v+ together / to the positive terminal of the 9v jack? Is the switch just grounded through the case?
reneshelle
Has thanked: 35 times
Been thanked: 47 times
Post by reneshelle »
the switch is not ground at all, and in this way it does not need to be.
It all looks fine, but if you need both battery and a 9v adaptor jack you need to use a switched 9v jack type. Also make sure that you use an isolated 9v jack (no metal touching the enclosure) type.
Lemmings
Post by Lemmings »
Thank you! :D
No battery in this build and i'm using a plastic 9v jack, so it should be good to go.
