MOOG Moogerfooger MF-103 12-Stage Phaser [schematic]
- Lithium_Grim
It will work, but the question is if it will sound nice. The layout will be huge with 6 LM13700 and parts....
Where is the LFO?
Where is the LFO?
I only give negativ feedback and y'all love it!
Hi Guys,
funny that this thread just got revived. I've been working with raindog's schematic together with the "official" one posted here recently, to create a schematic for a new pcb layout (hopefully fitting in a BB case). I was just wondering, if anyone here can think of a reason why one would NOT be able to just switch the CB4053N for a mechanical (foot)switch?. I'd probably also consider adding an option for "true bypass" to the board, as I usually have a buffer in my tuner pedal before it. Also, would there be a significant benefit of increasing the 6/12 stage switch to 2/4/6/8/10/12 switch? would it make a significant difference?
@djathey, I'd love to help, but that's waaaay to little information. Where's the rest of your schematic, what does your layout look like? All we can do with the info provided is compare your schematic to raindog's one and I'm sure you are more than capable of doing that yourself
Thanks,
Max
Thanks,
Max
I am using this as a way to simultaneously learn eagle, while attempting to layout a multboard eurorack mf103: one board for controls/mixing et al., and one board for phase.
It's still a work in progress.
However, noticed the following: while r100 appears in 'official' schematic, I could not find an 'r100' on the actual board, so this may be extraneous.
To help me identify things, I took a gutshot photo, and added some labels for CN1, see attached.
- The G
- Grease Monkey
2 stacked boards now: audio and phasers, for use with 20HP eurorack (80x100mm board sizes)
MF phaser phasers.pdf- (352.61 KiB) Downloaded 168 times
MF phaser audio.pdf- (452.5 KiB) Downloaded 172 times
Attempting to make this usable for both eurorack and stompbox, using a separate 'jacks' board: one for 3.5mm and a different one for 6.35mm (1/4"). Trying to keep all boards now within 80x100mm limits of free version of eagle, for now...
MF phaser thonkiconn jacks.pdf- (65.62 KiB) Downloaded 150 times
First draft - hope these don't wind up just being fancy trivets...
MF phaser-phasers draft.pdf- (159.59 KiB) Downloaded 150 times
MF phaser - 6_35mm jacks draft.pdf- (39.67 KiB) Downloaded 145 times
Alpha/untested version of all boards: need to rely less on autorouter.
• Utilized a 'sandwich' of 3 boards: Control, Phasers and Audio, with headers to form a kind of 'bus', to send signals between boards.
Trying to keep overall form factor small, especially for eurorack use.
• 2 interchangeable 'jacks' boards: one for eurorack (3.5mm) and one for stompbox (6.35mm; 1/4")
• Powered from either 2.1mm dc power (12vdc) or eurorack 10pin power connector (+/-12vdc).
• The voltage regulators are overkill, but I'm more or less familiar with them, so I went with what I knew.
Still need to noodle out a front panel layout...
MF phaser RS jacks.pdf- (241.51 KiB) Downloaded 102 times
MF phaser audio no jacks.pdf- (198.51 KiB) Downloaded 106 times
MF phaser phasers.pdf- (229.14 KiB) Downloaded 117 times
MF phaser controls.pdf- (172.63 KiB) Downloaded 103 times
MF phaser 6_35mm jacks.pdf- (64.29 KiB) Downloaded 109 times
Draft of pcb's: there's no turning back now...
MF phaser pcbs.pdf- (2.77 MiB) Downloaded 159 times
Time to give this project some 'wiiings': have sent boards out to be made.
MF phaser ALL.pdf- (847.59 KiB) Downloaded 168 times
