MOOG Moogerfooger MF-103 12-Stage Phaser [schematic]
I haven’t completed this yet, so it’s an unproven effort, so far.
Definitely need to bump this project up, on list of things to-do…
I also probably should have used readily available 78xx/79xx regulators, instead of ldo’s.
I’d also like to add features used within this phaser (even/odd and buffered tap points):
https://www.birthofasynth.com/Scott_Sti ... _schem.jpg
Thanks for the interest.
- bumblebee
It’s a big project…a very cool one though.djathey wrote: ↑03 Mar 2022, 13:59 I haven’t completed this yet, so it’s an unproven effort, so far.
I’d like to get the EH Guitar Synthesizer 8000 (rack unit) up and running but that is a massive project for me. Still, I’m intent on doing it some time.
I currently have 6 projects going on (traces and builds) and I’m a procrastinator at the best of times.
If you can’t buy it, build it. If you can buy it, clone it.
- Scruffie
- Opamp Operator
Have you seen this thread? https://www.diystompboxes.com/smfforum/ ... msg1240673
I'm quite familiar with the unit if you need a hand...
- bumblebee
Yes, Scruffie….that’s what prompted me to want to do it.Scruffie wrote: ↑04 Mar 2022, 13:00Have you seen this thread? https://www.diystompboxes.com/smfforum/ ... msg1240673
Thanks for the redrawn schematics, too!
I will likely need a hand, lol. I’ll keep your offer in mind. Thanks!
What would be great is any gutshots of the 8000…if you have them. It seems it would be a modular type PCB system, yeah? That was my plan anyways.
There’s certainly no rush as it will be quite some time before I tackle such a large project as I have plenty of others on the list that take priority over it simply because of the complexity of the 8000 (to me).
- Scruffie
- Opamp Operator
Excellent, my plan to ensnare someone else in to helping working on it was successfulbumblebee wrote: ↑04 Mar 2022, 22:18Yes, Scruffie….that’s what prompted me to want to do it.Scruffie wrote: ↑04 Mar 2022, 13:00Have you seen this thread? https://www.diystompboxes.com/smfforum/ ... msg1240673
I'm quite familiar with the unit if you need a hand...![]()
Yup, got plenty of gutshots and access to two units through one I repaired and one I've been helping someone else repair.
There are indeed multiple PCB's, a master board with all the pots, switches and mixing and then 3 individual boards connected to that (the schematics are separated in to the individual boards) and a separate power supply board.
I'll try and remember to start a separate thread here with some shots tomorrow, if not, give me a poke.
- bumblebee
CoolScruffie wrote: ↑04 Mar 2022, 22:50Excellent, my plan to ensnare someone else in to helping working on it was successfulbumblebee wrote: ↑04 Mar 2022, 22:18Yes, Scruffie….that’s what prompted me to want to do it.Scruffie wrote: ↑04 Mar 2022, 13:00Have you seen this thread? https://www.diystompboxes.com/smfforum/ ... msg1240673
There’s certainly no rush as it will be quite some time before I tackle such a large project as I have plenty of others on the list that take priority over it simply because of the complexity of the 8000 (to me).![]()
I look forward to seeing inside this behemoth! (Will PM you in a couple of days if no images pop up)
Would you be able to post the Eagle files you used to order the pcb's? And is there a list of all the components needed anywhere? I'd be interested in working on it as well.djathey wrote: ↑03 Mar 2022, 13:59 I haven’t completed this yet, so it’s an unproven effort, so far.
- Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
- Has thanked: 27 times
- Been thanked: 75 times
Pretty cool, might be interesting to convert it to SMD, thanks!
(also, if anyone needs a BOM, run the BOM ULP on the schematic and presto!)
- mictester
There is a fundamental design flaw with this circuit - the LM13600 / 13700 is both noisy and distorted. Put a few of them after one another, and the problems will be multiplied!
- LaceSensor
wen demo? wen release PCB for sale?
- Whoismarykelly
Is the Moog design not companded? 12 stages of phase shift have a pretty high noise floor regardless of architecture without companding.
