Switching Positive to Negative ground (Octavia)
Hi there,
I did a search but I could not find a reassuring answer.
I think I figured out the positive/negative ground thing.
Let's say I want to build an octavia:
http://fuzzcentral.ssguitar.com/schematics.php
http://www.tonepad.com/project.asp?id=62
And I want to be able to switch transistors NPN and PNP versions.
To make this switch I have to:
Change the voltage supply (in my case switch the DC jack so + becomes - and visa versa)
Change all components affected (Diodes and Elco's)
Do I have to change the Germanium Diodes (1N34A)? On the fuzzcentral schematics they do not switch. Why is that?
Thank You
Thank You
- ansil
- my favorite amplifier: my hughes and kettner blue 30r
- Completed builds: 3 jcm 800 builds
4 vintage plexi builds
100 jungle kat boosts
5 blues pearl purplexed
hell i can't type this long it will piss off people what can i say i have been doing mods on toyz appliances gear sex toyz computers and such for 27 years. i started when i was 6 taking stuff apart. - Location: cleveland tn
- Has thanked: 14 times
- Been thanked: 13 times
- Contact:
so you want to replace all npns with pnps and pnps with npns? is this what i see that you are asking.
Yep...I know it sounds a bit stupid...but I'm learning here...
It's just that I don't understand why the diodes after the transformer don't change...And As I'm writing this I'm starting to understand I think...The diodes are there to stop current flow back to the transformer....and therefore should not be reversed..
Is that correct?
Sorry for the silly questions. I'm trying to learn
Thanx
Is that correct?
Thanx
- mysticwhiskey
The transformer + diodes form a full-wave rectifier, effectively doubling the input frequency (hence the octave effect). For example, using a sine wave as input:Vendt wrote:Yep...I know it sounds a bit stupid...but I'm learning here...
Is that correct?
Thanx
The diodes being germanium probably means they smooth out the rectification transition point (where the signal goes from negative to positive), but that's just speculation on my part.
- mysticwhiskey
Nope, you'd just get an inverted (negative) output if you reversed the two diodes:
lol...I am learning.
So I f there were no diodes there would be both a negative and positive signal that would counterbalance with result no signal...?
For arguments sake...If there was only one (lets say top) connection from the transformer to the output I would end up with only the positive part of the original sinewave. Switching the Diode would give me the negative.
And that reversed for the bottom part.
One output of the transformer "lifts" and the other "lowers" the signal.
It doesn't matter if the ground is 0V or +9V
As the sine wave is now doubled in frequency you get the octave up.
I'm still struggling with what the dotted line is..I mean is that 4.5V (ideal conditions)?
I'm sorry I can't quickly draw a picture explaining what I mean. Hope I'm clear enough.
- mysticwhiskey
No, you'd still get a signal out.Vendt wrote:lol...I am learning.![]()
Yes, assuming you mean the top diode is removed completely so there is no electrical connection between the top of the transformer's winding and the output resistor, then you end up with a half-wave rectifier:For arguments sake...If there was only one (lets say top) connection from the transformer to the output I would end up with only the positive part of the original sinewave. Switching the Diode would give me the negative.
And yes, reversing the diode gives you only the negative part of the signal.
It's just the AC ground reference - in the Octavia there's a capacitor immediately before the transformer that removes the DC component from the signal, so in this case the dotted line is ground (0V).I'm still struggling with what the dotted line is..I mean is that 4.5V (ideal conditions)?
