D*A*M - Grease Box  [traced]
phibes
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
I traced this one way back when it first came out and I found some better gut shots to confirm values. I'm surprised I didn't see a topic on it. Really nothing new going, just a fixed MKIII/MKIV Tone Bender variant with the tone control fixed. I know a lot of guys like the DAM stuff. In my opinion it's a more useful two knob version rather than the 2 knob Park Fuzz Sound which has the gain fixed rather than the tone control. Modifying a pre-existing layout should be a breeze for it.
Rock on and enjoy.
Grease-Box-Schematic.pdf
(12.79 KiB) Downloaded 922 times
Image Ken
beedotman
Has thanked: 402 times
Been thanked: 393 times
Post by beedotman »
I think that schematic is correct. Can post some gutshots one of the latest purple Grease when I'll back home. I think also have layout somewhere...
beedotman
Post by beedotman »
First units has 10nf input cap instead 15nf in GB-80.
beedotman
Post by beedotman »
Grease has really nice clean up, its sounds like blend between drive and fuzz - its not so gainy comparing to others MKIII/IV circuits, so I believe last trannie hfe should be around 60-80.
beedotman
Post by beedotman »
here is board from copper side - this jumper in read is one of Q1 leg
phibes
Post by phibes »
Nice! I'll compare it to my schematic.
Image Ken
beedotman
Post by beedotman »
beedotman wrote:- this jumper in read is one of Q1 leg
this is Q1 emiter
phibes
Post by phibes »
Can you check the pot values? I just went with normal mkiii/iv values.
Image Ken
beedotman
Post by beedotman »
and this is layout.
sorry for shitty work - I've done this in excell when I was bored at work :blackeye
i think its pretty much ok
beedotman
Post by beedotman »
phibes wrote:Can you check the pot values? I just went with normal mkiii/iv values.
Citec 100KA for both
beedotman
Post by beedotman »
and little more gut shots
phibes
Post by phibes »
Yeah that layout matches what I drew up. Thanks for the pot values! Consider this one verified.
Image Ken
beedotman
Post by beedotman »
trannies:
Q1 - Motorolla metal can OC75
Q2 - CV7004
Q3 - OC71
beedotman
Post by beedotman »
phibes wrote:Yeah that layout matches what I drew up. Thanks for the pot values! Consider this one verified.
cool! :thumbsup
azrael
Has thanked: 35 times
Been thanked: 87 times
Post by azrael »
awesome stuff! i love the MKIII design, so it's always cool to see variants.
beedotman
Post by beedotman »
redrawn layout
beedotman
Post by beedotman »
I have finished prototype with transistors on sockets and it sounds really nice. :D
I think Q3 should has little higher hfe - 85-105 to get proper bias on collector which is around 2.5V in orginal units.
For Q1 and Q2 I have used "standard" gains (50-60 and 70-80 respectively with medium leakage) but this circuit is quite elastic so there shouldn't be problems to get good sounding trio.
Very fun and highly recommended circuit! :thumbsup :horsey:
beedotman
Post by beedotman »
BTW... In latest batch AC125 trannies were used with 15K instead of 20K on Q3 collector.
G5120fx
Has thanked: 37 times
Been thanked: 29 times
Post by G5120fx »
beedotman wrote:redrawn layout
Nice Layout, thanks!
I just noticed that C1 and C2 have to be turned 180°! Or the shaded side is "+"
beedotman
Post by beedotman »
Yup! :thumbsup You're right! "+" should go to ground, I haven't noticed shading before. :blackeye
Will redrawn it again and post soon.
