D*A*M - Grease Box  [traced]
G5120fx
Has thanked: 37 times
Been thanked: 29 times
Post by G5120fx »
It would be cool if you could name the wires too. It´s not a problem, there´s a schematic in this threat but, if you redraw it (you don´t have to; just make a note that the positive side is shaded) you could add it.
I´m still waiting for some "Mojo" Components, then I´ll build it.
beedotman
Has thanked: 402 times
Been thanked: 393 times
Post by beedotman »
G5120fx wrote:It would be cool if you could name the wires too. It´s not a problem, there´s a schematic in this threat but, if you redraw it (you don´t have to; just make a note that the positive side is shaded) you could add it.
Will do! :thumbsup
beedotman
Post by beedotman »
Here it is! :horsey:
beedotman
Post by beedotman »
And another two layouts for small veroboards which should fit easily 1590B and 125B enclosures.
Trannies could be mounted on sockets.
One with 22K trimpot for Q3 collector bias and another with fixed bias resistor.
I've made both so consider these as verified.
beedotman
Post by beedotman »
And couple of boards ready for trannies and wires...
Jumpers are placed under board so it looks quite clean 8)
Sexy, the orange caps are Philips brand?
beedotman
Post by beedotman »
sinner wrote:Sexy, the orange caps are Philips brand?
Nah... Vishay BC Components :)
http://www.banzaimusic.com/Vishay-BC-0-1uF-100V.html
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
BC Components used to be Philips Components, and Vishay bought them. So Philips, BC or Vishay they're all pretty much the same thing. The date code will be what ties down what the company name was at the time! :mrgreen:
beedotman
Post by beedotman »
Refreshed layout with full wiring. 8)
gb-80.pdf
(15.33 KiB) Downloaded 97 times
beedotman
Post by beedotman »
Latest units with OC82DM has 680K/68K bias string on Q1B and 15K on Q3C.
And really fat transistor legs :D
John Lyons
Post by John Lyons »
I don't suppose anyone has had a peek at the GB-83 Silicon Grease Box have they?
pamaz
Has thanked: 32 times
Post by pamaz »
https://www.freestompboxes.org/viewtopic ... ilit=gb+83
20 seconds using the search function....
beedotman
Post by beedotman »
don't be rude :blackeye :roll: :lol:
John Lyons
pamaz wrote:https://www.freestompboxes.org/viewtopic ... ilit=gb+83
Easy cowboy, I did search and it didn't come up.
I found this thread though.
Must have only given it 15 seconds. :horsey:
Someone was kind enough to send me a link, thanks.
John
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
I'm just building the silicon version and your scarab deluxe - it will be interesting to compare them side by side!
beedotman
Post by beedotman »
New GB-88 version was introduced with added output capacitor blend (between 4700pF and 220nF).
Also input cap increased to 22nF in place of 15nF. Rest of compontents looks standard for 220K/47K bias string.
