Eagle Autorouter
soggybag
Completed builds: Fuzz Face, Tone Bender, Big Muff, ICBM, Ugly Face, Green Ringer, Super Fuzz, Multiplex Echo, Multiplex Jr, Rebote, Echo Base, SHO, Fuzz Factory, Titan Boost/Octave, Easy Face, Tone Bender MkII, Trem Shifter, Zero Point Mini...
Has thanked: 28 times
Been thanked: 27 times
Post by soggybag »
Can anyone post some pointers on using the Autorouting tool in Eagle? Seems this could be a time saver. I have it working and it makes a great two sided board. As a DIYer a singled sided board is what I really want, which seems trickier to created with the Autorouter.
I just noticed that the Autorouter seems to be working in the latest copy of Eagle. It didn't work in the older free version of Eagle.
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
You just make the layer cost 1 in the autorouter menu. And set preferred direction to N/A I guess?
DeanM
my favorite amplifier: Marshall VM 2466
Has thanked: 21 times
Been thanked: 5 times
Post by DeanM »
Hides-His-Eyes wrote:You just make the layer cost 1 in the autorouter menu. And set preferred direction to N/A I guess?
What does the * mean? I just installed eagle TONIGHT! lol and having manually routed a board i decide to check out hte autoroute. when i set it to the * for top layer it only used a few short and straight traces so is it fair to assume this means top is set to jumper layer? N/A wouldnt route because it was a microprocessor board and had too much goin on for just a single layer. Its just a guess that * is for jumper layers cos having only installed it this eve i haven't read over any of the manuals etc.
I have to say...it's a very cool piece of software! Its very easy to use! I learnt enough in an hour or two this evening to be able to pick a schematic and do a PCB in eagle! Really liked it!
PS: I'm used to using OrCad in college.
EDIT: quickly looked at the manual. for direction, * means none. :slap:
