Fet switch using CD4013 ?
Onafets94
Post by Onafets94 »
Hi! this is my first post here.
I'm sorry for my sometimes bad english, i'm 17 and still studying :D
when i saw the flipflop circuit used in every boss pedal, which is relatively complicated, i thought that i could make a good switching system using a D-type integrated flip-flop. the only one i know is the CD4013: very unexpensive (it would be better a single-one, but i didn't find any.
here's the schematic, half CD4013 is used. that RC circuit should work as a debouncing system
as the capacitor is not discharget, the voltage on D shuld keep the previous state. doing so, the effect caused by a multiple impulse caused by the switch bouncing should be eliminated.
are there any errors?
do you know any single d type flipflop IC?
are there any errors in the FET polarization?
EDIT sorry i forgot the attachment
