Bearfoot - Model H [traced]
- WhiteKeyHole
Can I get the Dale resistor values? Thanks!
- WhiteKeyHole
Also, could I get some information about the gain and tone potentiometer wiring? I have my assumptions down now but would like to be sure.
- WhiteKeyHole
Never mind, missed the pictures somehow. Sorry.
- culturejam
The 5-bands are Vishay CCF-55 series. I love those! I use them in a lot of my builds.WhiteKeyHole wrote:Can I get the Dale resistor values? Thanks!
Yes, I know that's not what you were asking about, but I just had to comment.
- WhiteKeyHole
Thanks. What's the resistor just above the 4n7 capacitor? Is "R4" 22K?
That should be it, thanks for all the help.
- WhiteKeyHole
As always, there may be revisions.
- mhr1.png (9.79 KiB) Viewed 6357 times
- Jack Deville
Re: schematic above:
I don't think the connections on Q3 and Q4 are correct.
- WhiteKeyHole
Yeah, I think it's suspect. Went by what I can see, though.
- WhiteKeyHole
He uses them in the same way in the Fire Red Fuzz,
- WhiteKeyHole
Wait, never mind. Why don't you think it's correct? Makes sense to me...
- Jack Deville
N channel JFETs' drain and source tied together?
Drain and source to ground at Q3, bypassed entirely at Q4?
Explain how this makes sense.
- RnFR
yeah, that doesn't look right. maybe check the pinouts?
- WhiteKeyHole
I did check the pin arrangement, would be foolish not to. Anyway, seems like a diode to me. Gate being the anode, drain/source being the cathode. To quote Wikipedia, "The gate(G) (control) terminal has doping opposite to that of the channel, which surrounds it, so that there is a P-N junction at the interface."
What am I missing? How else are you going to use a JFET as a diode?
- WhiteKeyHole
Other than using it as a current source.
- WhiteKeyHole
- RnFR
easy buddy. I stand corrected, you can do it that way. but I'm used to seeing it one of these two ways, usually the one on the left.
http://www3.hi.is/~voe1/Posted/jFET_clip_cir.jpg
- WhiteKeyHole
J1 and J2 are, basically, the same configuration found in the Model H. J3 and J4 are the other method I mentioned, the JFETs are configured as current sources (regulators, limiters, what have you).
- culturejam
I thought the same thing at first about having the drain and source tied together, but apparently it works that way as well as a diode.RnFR wrote:easy buddy. I stand corrected, you can do it that way. but I'm used to seeing it one of these two ways, usually the one on the left.
- WhiteKeyHole
Yeah, R15.
- earthtonesaudio
A JFET wired like that makes a "low leakage" diode. You'll sometimes see them used in low-drift peak detectors or sample/hold circuits.
