3PDT as on/on in midi stompbox?
rudeez
Post by rudeez »
Hi.
I've built a stompbox to control midi using a usb gampad.
The current schematic makes it acting as a on/off switch.
Basiclly it means i have to press the switch four times to have it act as a signal sender.
Pressing it causes the midi signal to stay active instead of activate and deactive as it should have done with a momentary switch.
Thing is i need to keep the on/off function for the LED since the gamepad pcb can recive midisignals.
Im attaching a pic of the scheme i made and are using right now.
I would like to know if it's possible to wire the switch act as on/on, send a signal when pressed and release it at the same time.
I've done a post in another forum about the build with plenty of pics in the first post, take a look so you get a picture of what it is.
http://www.djtechtools.com/forum/showthread.php?t=32534
Thanks in advance!
/Jimmie
