Actually, here's a schematic of the way the wiring will work:
At least, I think it should work that way. Feel free to critique.
But anyway, the guitar has two split coil pickups with four conductors each. The idea is to use them as a normal 4-way telecaster would be used in mono mode and to have a second mode which splits the top three strings from the bottom three strings and is controlled like two 4-way teles which can then be sent out either in stereo to two amps or, with the use of another switch, be mixed back down to mono in either series or parallel and in or out of phase with the other half of the strings. This SHOULD allow any combination of two coils to hum cancel.
Anyway, the two mono/stereo split switches (one on the left and one to the right of the bridge pickup's representation, here) should really be one switch but it would have to be a 5-pole (or more) double throw switch.
I can't seem to find one like that. Anyone have any ideas?
