Wampler - Ecstasy  [traced]
rocklander
Has thanked: 1404 times
Been thanked: 227 times
Post by rocklander »
so this?
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
yep!
rocklander
whew! thanks muchly.. :hug:
... will have a go (maybe this weekend) at a 1590a board...
rocklander
have run over this a couple of times.. pretty sure it's okay, but happy to be told I've goofed. ecstasy in a 1590a layout
[now built and verified]
20150308 - uploaded the expressPCB file as requested :D
ecstasy1590a-groundplane.1.02.pcb.zip
(12.64 KiB) Downloaded 214 times
alexradium
Has thanked: 64 times
Been thanked: 68 times
Post by alexradium »
rocklander wrote:have run over this a couple of times.. pretty sure it's okay, but happy to be told I've goofed. ecstasy in a 1590a layout
i just looked at a more recent version,first input cap is 33nF,47p ceramic disc between pins 6/7,22R on supply, 100n multilayer from V to ground near the IC,dividers are made by 47k for the diodes,the rest is 10k,elko caps 47uF.
rocklander
more recent version of the box itself, or more recent version of the schem? if you have the schem, can you link/post? :thumbsup
alexradium
schematic is the same,just slight different values,no big tonal changes anyway.
alexradium
to be complete,this board needs a diode for reverse polarity protection,and a res/cap for supply filtering,i mentioned the values before.
Plus,a resistor from 9V for the led,optional.
rocklander
to adjust the layout, I need a schematic.
I used this one. https://www.freestompboxes.org/viewtopic ... 20#p197137
if you want changes to the layout, please provide a verified schematic... or don't use the layout.. makes no bones to me.
rocklander
I have now built this layout and it's tested as working verified. it's quite a diverse unit.. will see if I can squeeze all that hardware into a 1590a enclosure next.. eep! :whappen: :blackeye
rocklander
and here's the build
guts
thn.technik
my favorite amplifier: Laney
Completed builds: Shred master, Tube screamer, Reezafratzitz, SansAmp GT2, RAT, Okko Diablo, Metal Simplex...
Been thanked: 44 times
Post by thn.technik »
I find this another photo of Ecstasy, but someone know what is this marked capacitor?
alexradium
100pF
snofla1900
Has thanked: 83 times
Been thanked: 7 times
Post by snofla1900 »
answer : 100 Pf
This seems very unlikely to me that a Wima cap that size would be 100 Pf more like something Nf !
beedotman
Has thanked: 402 times
Been thanked: 393 times
Post by beedotman »
answer : 100 Pf
I have 220pF or 470pF Wima's bigger than 100nF, nothing strange here.
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
snofla1900 wrote:This seems very unlikely to me that a Wima cap that size would be 100 Pf more like something Nf !
I've got some 100pf Wima caps that are that size.
snofla1900
Okay you convinced me ! Sorry .
I thought I knew it all , it appears I've never seen these before !
I'm only familiar with pf type caps in a much smaller housing.
Alf
jimini
Has thanked: 29 times
Post by jimini »
Hi
One thing I don't get circuit -design wise is:
Why does every opamp and the diodes (D1,D2)get their 'own' voltage reference?
Is that really such an improvement versus one for all?
Regards JM
jymaze
Has thanked: 86 times
Been thanked: 171 times
Post by jymaze »
No, they don't need their own voltage reference, it is overkill. I would use only one voltage divider and make sure it is filtered well (you can also add a 22n poly cap in parallel with the electrolytic cap, it is even better).
jimini
Post by jimini »
Great,
So one can even reduce the part count of an already easy circuit!
Thanks Jymaze
