Snarling Dogs - Erogenous Moan
Posted: 07 Jul 2011, 00:13
by acdc518
Here are the guts to a cool volume pedal that can simulate a backwards guitar. Sorry about the picture quality my camera refuses to focuswhen i use the zoom.
Image Image Image
the IC chips say: U5: too small to read.
U3 and U4: HCF4016BE
W990A9735
Malaysia
U2: 4558D
JRC
7398B
U1: MC14013BCP
FOL9806
Re: Snarling Dogs: Erogenous Moan
Posted: 01 Nov 2011, 03:58
by !@#$%^&*
I would love to have schematic for this one w/ layout and soundclip :D
Posted: 01 Nov 2011, 05:05
by RnFR
do you have a macro setting on your camera? that usually helps a lot for gutshots.
Snarling Dog Erogenous Moan Pedal Issue
Posted: 13 Mar 2018, 19:40
by Stevenrb718
I have a Snarling Dog Erogenous Moan Pedal where only the volume pedal side of the unit works. Clicking the switch to use the reverse side does nothing, no change in sound or LED lighting up. The wiring seems to be stock but I have nothing to compare it to, so I'm not sure. Any help on this would be greatly appreciated!
Re: Snarling Dog Erogenous Moan Pedal Issue
Posted: 13 Mar 2018, 20:56
by dv8r601
Take good pics of the front and back of the pcb. The guys here are experts at pointing out dodgy solder joints and other faults.
Posted: 17 Apr 2018, 05:11
by Stevenrb718
Here are some pics. Is there a way to test the switch firstly?
Re: Snarling Dogs - Erogenous Moan
Posted: 22 Apr 2018, 19:21
by digi2t
This is what I have so far. I'm working on the schematic.
Posted: 31 Oct 2018, 19:46
by Aharonimacaroni
I have one and love the enclosure,the pedal developed a click at the end of the run,I gave it a whirl and changed the volume pot side and the click was gone ,the original pots are sealed,the backwards tape effect sucks but I will try changing the pot and see how it goes.
Posted: 02 Nov 2018, 18:44
by scoop
thanks everyone for investigating this thing, I've always wanted to try it but never shell out for.
Aharonimacaroni wrote:I have one and love the enclosure,the pedal developed a click at the end of the run,I gave it a whirl and changed the volume pot side and the click was gone ,the original pots are sealed,the backwards tape effect sucks but I will try changing the pot and see how it goes.
I might be wrong I have never used this pedal but based on the description, I thought the "click" was an intended feature on the pedal
The Erogenous Moan is a volume/reverse volume pedal, and can be used as a straight volume pedal. Pushing the footpad causes the volume to swell. At the end of the sweep, the volume cuts off completely. Reversing the process, the volume kicks in, and swells again. At the top of the sweep, the volume cuts off with a simulated click of a guitar pick.[/b] The effect is haunting.
More than 23000 guitar effects pedals from 4000 brands:
http://www.effectsdatabase.com/model/sn ... genousmoan
Posted: 03 Nov 2018, 00:03
by roseblood11
@digi2t: Did you finish the schematic?
Re: Snarling Dogs - Erogenous Moan  [schematic]
Posted: 03 Nov 2018, 10:46
by digi2t
Yeah. Here's what I have. Didn't have time to validate it to the board trace tho, so you might want to check it yourself.
Posted: 30 Dec 2018, 17:06
by Manfred
I create this approximate PCB-Clone:
Ready to print PDF-files:
erogenousMoanComponentSide.pdf
(18.71 KiB) Downloaded 124 times
erogenousMoanSolderSide.pdf
(9.72 KiB) Downloaded 111 times
erogenousMoanSolderSideMirrored.pdf
(9.73 KiB) Downloaded 107 times
SprintLayout6-file:
ErogenousMoan.zip
(26.09 KiB) Downloaded 112 times
Posted: 10 Oct 2019, 17:07
by Stevenrb718
Thanks for the schematic. It definitely helped for wiring up the switch. However I still have the same issue of the volume side working but the reverse doesn't work. Which IC controls the reverse of the pedal?
Posted: 08 Apr 2023, 22:05
by Axtman
Hello,
I am looking for a picture of how the mode switch on the side is wired. Can some one please take a picture for me?
Also where can I buy (or make) a bottom panel?
