D*A*M Super Bee
Original effect designs complete with schematics, layouts and instructions. Freely contributed by members or found in printed or online publications. Cannot be used for commercial purposes without consent of the respective owners of the copyright.
beedotman
Has thanked: 394 times
Been thanked: 391 times
Post by beedotman »
Hi fuzz freaks!
Heres layout for Super Bee - basicly its Vox Tone Bender circuit type with input and output cap changed to 100nF.
Many different types of trannies where used, just use your favourite gain buckets - I like 60-75 hfe for Q1 and 75-105 hfe for Q2, or something like this, theres no magic numbers - always breadboard trannies before soldering and use Your ears :)
You can move R5 resistor (led pulldown) on switch, as in SB-66 version.
Some gutshots:
Peace,
b
beedotman
Post by beedotman »
and the latest SB-66 version with Suntans caps instead Eros.
atreidesheir
Has thanked: 444 times
Been thanked: 42 times
Post by atreidesheir »
How much advantage is gained by insulating the transitor legs?
The DAM stuff is always nice to examine. Nice work. No Jack Deville, but really nice at the craft.
Has thanked: 147 times
Been thanked: 138 times
moved to proper forum.
Has thanked: 98 times
Been thanked: 271 times
Post by DrNomis »
atreidesheir wrote:How much advantage is gained by insulating the transitor legs?
The transistors are germanium types and are sensitive to heat, if you solder them in place with short legs, you run the risk of damaging them from excessive heat, so to get around that, you solder them in with a bit of extra leg length, Insulating the transistor's legs basically stops them from shorting-out, it also helps when identifying which leg is the Base,Emitter, and Collector..... :D
atreidesheir
Quick sorting the emitter, leg and collector... :thumbsup Capital idea, sport!
beedotman
Post by beedotman »
BTW... Level pot value (100K Log) is not confirmed value, just my guess. I will use 100K Lin in my build.
beedotman
Post by beedotman »
built in progress...
board ready for trannies
beedotman
Post by beedotman »
new CV8314 (OC76) and AC125 loaded unit
bigmufffuzzwizz
my favorite amplifier: 1973 Sunn Model T
Post by bigmufffuzzwizz »
These all look great! Thanks for sharing your layout. When you said to breadboard the transistors first, what's the purpose of doing that? Does it have something to do with adjusting the collector resistors if needed?
Magic Pedals Home of The Shrine Fuzz!
Post by DrNomis »
I particularly like the idea of using cable-ties to keep all the wiring nice and neat, something that I might start doing with all my future stompbox builds.... :thumbsup
beedotman
Post by beedotman »
Finished build with OC81. Sounds really great, IMO better than original one :lol:
Brighter and little more gainy (used hfe - around 75 for Q1 and 115 or something for Q2).
So layout is verified!
beedotman
Post by beedotman »
bigmufffuzzwizz wrote:These all look great! Thanks for sharing your layout. When you said to breadboard the transistors first, what's the purpose of doing that? Does it have something to do with adjusting the collector resistors if needed?
No. You can try how transistor sounds like before soldering them and choose best sounding pair (if You have some to choose from...). Just pick wich You prefer most with less noise.
You can adjust Q2 volatege using trimmer. Just like sundial in sunfaces.
beedotman
Post by beedotman »
Confirmed Level pot value - Linear 470K (but it's little to dark for me - I preffer linear 100K).
Bees are biased to get around -6V on Q2 collector.
beedotman
Post by beedotman »
An refreshed layouts with full wiring!
sb-66.pdf
(18.15 KiB) Downloaded 91 times
beedotman
Post by beedotman »
And here's vero layout to use sockets for trannies.
[smilie=a_fro.gif]
beedotman
Post by beedotman »
small correction on 470pF cap
bee_fuzz.pdf
(61.17 KiB) Downloaded 87 times
Guava
Post by Guava »
Sorry to bump an old thread, but having some trouble with the sb-66 layout. First post from a longtime lurker!
I built a Super Bee according to this layout with an added voltage inverter and am not getting any signal with the pedal on (getting sound when bypassed). I'm using an OC71 for Q1 and an OC76 for Q2, using open frame mono jacks and no battery (so I brought a ground wire to the input jack from the top row, also from the level pot and the ground from my inverter board), and have my input jack wired correctly for the inverter (standard negative ground wiring at the DC jack, then the inverter board wires to the Super Bee board and to ground).
Does anybody have any ideas? Thanks for any help!
