HI
Can anyone tell me the difference and preferability of 3mm vs 5mm LEDs for clipping?
Im sure Ive seen 3mm and 5mm both used, is there a difference if the forward voltage is the same?
What about mixing and matching?
Ive read a bit about colours too if someone wants to give any guidance on that while they are here, im all ears
3mm vs 5mm for clipping LEDs
- LaceSensor
- DrNomis
- Has thanked: 98 times
- Been thanked: 274 times
LaceSensor wrote:HI
I'd say that the forward voltages of 3mm Leds are the same as for 5mm Leds, but, the current consumption may be different, especially for 3mm high-brightness Leds, different colours do have different forward voltages, with blue leds having the highest at about 3.5V or so, if you're using them as clippers, I can't see any reason against mixing or matching, so give it a go and see what you get out of them...
- LaceSensor
Thanks for the reply, Doc.
